Show multiple variable instance in a panel table
I have zabbix as datasource ad I have a value with multiple instances (example: interface speed: I have a value of interface speed for each interface).
I configured in grafana a variable for the interface name, so when I configure my panel I use the variable insted the name and one panel is ok for each interface I want to see.
I’d like to have a panel (table or graph) with all the values, without configure a lot of query, but using the variable. It’s possible?
Thanks
ig
