Hi all, I have recently started using the Grafana Geomap panel, but I have seen that I needed some features that it doesn’t offer me. I found Orchestra cities map, but it doesn’t have all of them either, so I thought to build a plugin with just what I need, but one of the most important features is the shared view. The problem is that I don’t know and I can’t find the way these plugins use this feature.
The other option is to be able to enable and disable layers in the Geomap plugin itself, but I haven’t found how to enable this option either.
Thank you very much.
