I want to insert an embedded panel in a web page with the tag, I make the change in the grafana.ini file, changing allow_embedding = true and auth.anonymous, I uncomment the lines and restart the grafana service but I get this error " This request has been blocked; the content must be served over HTTPS. ", Am I performing a wrong step?
Hi @mddelgadob,
Not sure whether this is causing your issue, but you may also need to uncomment the “cookie_samesite = lax” line. I used the post below when setting up my dashboards on my Hubitat system:
Simon
Thank you very much for the answer, the problem was because I did not have ssl certificates installed to grafana and from the web page that was including the panel I had certificates. already solved
