Trying to embed Grafana panels or dashboards in my organization's website
    8.0.0 and Windows 10
    I’m trying to embed Grafana panels (sourced from Prometheus) in my company’s website.
    I’ve tried taking the embed iframe link and pasting it into a div on the website. I’ve also tried using the direct links for both panels and dashboards inside an iframe or inside an img tag.
  • What happened?
    In all cases the panel/dashboards do not load. In the case of the iframes, I get an error over the iframe that says the website https://mywebsite… (Not my actual site) is unavailable or has permanently moved. In the case of the img tags, I get a console error that states ERR_CERT_DATE_INVALID in chrome (similar errors in edge).
I have tried adjusted the defaults.ini and custom.ini files to allow embedding, as well as various other configuration changes suggested in similar topics on these forums including to allow anonymous viewing.
    I expect the panel or dashboard to load in the iframe/img tag.
    For security reasons, I can’t copy/paste my source code, the grafana link is for our domain, but it’s similar to "https://192.168.xx.xx:3000/d-solo/.../windows_exporter-for-prometheus-dashboard?orgId=1&from=1665587871583&to1665598671584&panelId=53 " (Some values altered for security).
    If I open this link, or the same link but http://…:80 instead, I get the expected panel in the browser. Firewalls on both the Host Grafana machine and my client are turned off.
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No
    Just the various suggestions found here on these community forums.
