Dashboard (using iFrame) not opening in web broweser window
I am sharing the Grafana dashboard using the following link in a webpage
The way I had done is I had copy pasted the above link into an HTML file dashboard.html and tried to open the file dashboard.html through browser. http://platform.mylabs123.com/dashboard.html
When I open this in browser - The browser shows me the following error
This content can’t be shown in a frame
There is supposed to be some content here, but the publisher doesn’t allow it to be displayed in a frame. This is to help protect the security of any information you might enter into this site.
Try this
  • [Open this in a new window]
I had tried changing permission in my webserver(apache2) but I am not able to resolve. If any of you has faced this issue can you give me some tips ?
Regards
Girish
In Grafana 6.2 , there are two options in defaults.ini which restrict iframes
allow_embedding: false
cookie_samesite: lax
Change above two settings as below to make iframes work
allow_embedding: true
cookie_samesite: none
Thanks Rahuls.
But this changes did not help me. Yes, I am using grafana 6.2.2. I ma attaching the iam attaching the image for your reference
I keep seeing the message content can’t shown in frame. What the browser says is:
"There is supposed to be some content here, but the publisher doesn’t allow it to be displayed in a frame. This is to help protect the security of any information you might enter into this site.
Try this
**** Open this in a new window***
Did you remember to restart grafana after changing the config file?
Yes, I did restart the grafana every time I made changes to the config files
Still it is not working. Have you tried this iframe and did it work for you
Regards
Girish
No, I have not tried it, I was just suggesting something that might be the problem.
I have this working. Can you show your config.
Hi Rahuls.
Thanks for the support
Here is the path to defaults.ini (I had uploaded to GitHub as I am not able to copy paste here)
Regards
Girish
Hi Girish,
You seem to have changed the value but missed to uncomment them, remove “;” at the begining of line
set cookie SameSite attribute. defaults to lax. can be set to “lax”, “strict” and “none”
cookie_samesite = none
set to true if you want to allow browsers to render Grafana in a. default is false.
allow_embedding = true
Thank you very much Rahul, The issue is resolved when I removed the semi colon.
I thought # is for commenting did not know ; is also for commenting. So I guess both ; and # can be used for commeting
Hello, i have the same problem. I followed the instruction a those pages:
I modified the file sample.ini in grafana folder (I am using win 10 pro), but I cannot visualize the frame
web
Can you help me in solving this problem?
I am using grafana cloud pro.
Thank
Filippo
Hi Guys, I am experiencing exactly the same problem. The iFrame address is like:
I cannot open this iFrame.
I have done the configuration like this:
I am using Grafana Cloud Trial version. We need to the complete this evaluation before we can get into a contract.
Thanks for any help.
If anyone else stumbles on this and needs the solution -
Edit disable_sanitize_html to true in the default.ini file. This is located in /usr/share/grafana/conf/ for those trying to locate it in the prebuilt Docker container.
Save the file
Restart Grafana or the Docker container
Make sure to fully refresh the page (Ctrl+F5) you are trying to have an embedded iframe located in
