johans
April 7, 2023, 7:27pm
1
Running Grafana v8.4.6 OSS
I want to embed a panel in my node-red flow. I have updated my grafana.ini
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
;allow_embedding = true
If I look under Server Admin → Settings → security
Why do the two not match? I did stop and restarted Grafana.
So the issue I am experiencing I can’t iframe a panel.
:Hi @johans ,
Thanks for opening this post.
remove the “;” in front of allow_embedding = true i.e.
Then restart your grafana server and you should see this to true under Server Admin → Settings → security
Then iframe should work !!
Let us know if you need any help on this.
johans
April 12, 2023, 6:19am
4
What setting must the auth be on?
As if I log in I can see the user name and password is correct, but it kicks me out.
Hi @johans
We have this documentation for the Authentication:
Please check as I do not know in detail what Auth mechanism you are using. Also it seems a different question than Embedding panel (which comes in Dashboard Category).
So suggestion would be to use the Authentication Category to get help.
