I’m getting the following error:
535 5.7.8 Username and Password not accepted
I have tried many solutions found in these forums but none seems to work.
I know Gmail use to have a setting " Less secure app access" but you can’t use it anymore.
Is it still viable to use Gmail in Grafana without this setting?
If it is, how?
I believe you now have to use what Google calls “App Passwords”. And to use them you need to enable 2-factor authentication on your Google account. See here:
getting a bit crazy about that one, not sure I’m missing an obvious thing, but since I’m getting close to giving up, time to call for help
I have a Home assistant running like a charm on RaspPi 4, latest Core, Supervisor, OS, FE versions, installed the grafana add-on over the week-end to get up to speed on « Monitoring & Observability », starting by monitoring my Internet connection.
InfluxDB created, added as a data source to Grafana, first grafana dashboard looks pretty cool (although very basic), setting up thresholds, happy bunny, until I want to send alerts. I’m not going to use PagerDuty for home appliance (that would be over the top), so email alert will do, if only it would work
This is the issue:
logger=ngalert.sender.router rule_uid=f21331a5-c7f6-49f0-9ca4-6adfae7d742f org_id=1 t=2023-11-22T20:45:00.280128903+01:00 level=info msg="Sending alerts to local notifier" count=1
logger=ngalert.notifier.alertmanager 1=(MISSING) t=2023-11-22T20:45:00.606234641+01:00 level=error component=alertmanager orgID=1 component=dispatcher msg="Notify for alerts failed" num_alerts=1 err="grafana-alert-email/email[0]: notify retry canceled due to unrecoverable error after 1 attempts: failed to send notification to email addresses: mymaill@gmail.com: EOF"
My SMTP config looks like that (home assistant config style)
I am using the so-called app password from Google Mail and I have confirmed that it works as I have been able to generate emails with other apps (InfluxDB for example). Any idea what the issue could be?
