I understand how to output labels as columns in Explore.
However, how should I set up the table and logs panels in Dashboards?
Could you describe in more detail what you want to do and where your problem lies?
I am collecting application logs with loki, and I am listing log messages with a table panel.
However, the table panel shows columns such as Time, Line, tsNs, and id.
In the Explore screen, if you select a label, it is expressed as a column,
but the table panel in the dashboard does not.
When using the table panel in the dashboard,
I want to show the label value as a column.
Is there a way?
