How to use parse function labels as Grafana Table Headers
Hello, I have an NGINX log stream that’s consumed by fluent bit and sent to loki with extra kubernetes labels. The raw log line looks like this
  "time": "2025-02-24T01:50:26.80345792Z",
  "stream": "stdout",
  "_p": "F",
  "log": "47.29.201.179 - - [28/Feb/2019:13:17:10 +0000] \"GET /?p=1 HTTP/2.0\" 200 5316 \"https://domain1.com/?p=1\" \"Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.119 Safari/537.36\"",
  "kubernetes": {
    "pod_name": "pod-name",
    "namespace_name": "namespace",
    "pod_id": "uuid",
    "labels": {
      "app": "app",
      "pod-template-hash": "template-hash",
      "variant": "pod-variant"
    "host": "host-name",
    "pod_ip": "1.1.1.1",
    "container_name": "container-name",
    "docker_id": "dockerid",
    "container_hash": "container has",
    "container_image": "container image"
The real log is located in the log field in the JSON. What I want to do is only extract the NGINX log and create a table with headers that can explain each NGINX log field. For example
| req_ip | req_time | HTTP req | etc.
This is my current logql
{app="app", variant="pod-variant"} | json nginx_log="log" | line_format "{{.nginx_log}}" | pattern `<req_ip> - - [<log_timestamp>] "<request>" <req_http_status> <req_body_size> "<http_referer>" "<http_user_agent>"`
With this query, I am able to get only the NGINX log part and extract the labels from the NGINX log. However, when I change my visualization to Table, the listed columns are labels, Time, Line, tsNs, and id.
Is there any way I can use the labels extracted from pattern function as my Table Headers?
Transformation - Extract fields
with {} Labels as Source
and “Replace all fields” checked
Try changing your query type from rangy to instance. A screenshot would also be helpful.
This worked. Thank you!
