Inquiry on using grafana logs panel
Is it possible to output labels as columns in the table or logs panel?
Yup! In the logs panel, click on a log line to open the log details, and then click on the “eye” icon to replace the log message with the value of that label (or metadata/field).
Here’s an example on play
Similarly with the table panel, but instead just click on the checkbox associated with a label (or field/metadata). Here’s an example on play
