Setting the value for the graphics
Hello !
I have a problem with my graphics :confused:
I have a Zabbix agent on my pfsenses that pulls up all the info in the Zabbix and then in the grafana.
As you can see on the screenshot, the values are incorrect… How can I get a better value knowing that I would like the percentage of RAM available.
I thank you in advance :slight_smile:
hmmm, if this is a problem with your query @Team-off, then I would suggest maybe making an issue in the Zabbix plugin repo. The plugin author is a Grafana engineer and quite responsive :+1:
Hey @anon70503803 !
The person of the zabbix plugin or the person who created the zabbix agent on pfsense?
sorry, I meant the author of the zabbix datasource plugin for grafana :+1:
