am using Grafana in version v7.4.3 and I am having problems with Pie Chart plugin (Version 1.6.1). When using the plugin with DataSource Zabbix (Version 4.1.4), there is no information.
If you use the Pie Chart plug-in with DataSource Mysql or Influx DB, it will bring information normally.
Could they help?
The problem was with the zabbix plugin. Downgraded to version 4.0.2 and worked normally with Pie Chart plugin. But the stack graphics were a problem.
Upgraded the zabbix server to 7.5.0-beta2 and so far everything is working normally and the latest versions of the zabbix plugin. But only the Pie chart v2 plugin that is working for pie charts.
