Not able to pull some data from Zabbix into Grafana
Creating a gauge that pulls (example Zabbix Agent Version) last data is nothing. I can see in latest data in Zabbix the information I want. In Grafana nothing is there.
can you please follow these steps to share your raw unformatted data? That way, the community can try and mock up your problem :+1:
Data from Zabbix showing the correct data.
Issue appears to have been a performance issue with the Grafana. After migrating to a VM and increasing resources the issue went away.
