Hello guys. I have grafana which works whith zabbix plugin. I have a some problem with the display of data on the graph. I created template for few servers.
I can’t understand, why “total memory” display incorrect?
Can be the reason for the interval of updating the items?
rss:10sec total: 1800 sec
any ideas?
I am hope for your help. thx
torkel
July 19, 2017, 7:55pm
2
maybe you have enabled stacking?
torkel
July 19, 2017, 7:56pm
3
you should check the response from Zabbix as well, to know if its an issue with Grafana or your Zabbix query:
If you get a panel query error or not seeing the data you expect to see the most important thing to do
is view the query Grafana sends to your database and what the raw response is. This information is not built into Grafana yet but can be easily investigated using Browser Dev Tools.
To open Chrome Dev Tools (F12, Ctrl+Shift+I on windows, Cmd+Opt+I on Mac), go the network tab. Hit refresh on the Grafana dashboard so Grafana sends a new data query. Try to find the query in the list of network c…
