Set UI Design in Public Dashboards
    10.0.1
    I am using UI Design light as default in my Grafana 10 installation. I want to create a public dashboard with UI Design dark.
    I use the GUI to create a public dashboard with time picker and annotations enabled. I don’t have the option to select Dark Design.
  • What happened?
    When accessing the public dashboard, it gets displayed in Light Mode.
    I expected Light Mode, but had wished to display the dashboard in Dark Mode.
    n.a.
    no
    I tried to get more information at Public dashboards | Grafana documentation but the information there seems different to the behavioud on the GUI at the current moment.
