I am using postgres and enable session and configure the postgres username and password, then i restart the service. But the service got failed. From the log i could not find much information. I m using postgres94 version.
FYI:-
t=2017-04-26T11:48:52+0800 lvl=info msg=“Starting Grafana” logger=main version=4.2.0 commit=349f3eb compiled=2017-03-22T18:06:41+0800
t=2017-04-26T11:48:52+0800 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2017-04-26T11:48:52+0800 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2017-04-26T11:48:52+0800 lvl=info msg=“Config overriden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Config overriden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Config overriden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2017-04-26T11:48:52+0800 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2017-04-26T11:48:52+0800 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2017-04-26T11:48:52+0800 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2017-04-26T11:48:52+0800 lvl=info msg=“Initializing DB” logger=sqlstore dbtype=postgres
t=2017-04-26T11:48:52+0800 lvl=info msg=“Starting DB migration” logger=migrator
t=2017-04-26T11:48:52+0800 lvl=info msg=“Executing migration” logger=migrator id=“copy data account to org”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Skipping migration condition not fulfilled” logger=migrator id=“copy data account to org”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Executing migration” logger=migrator id=“copy data account_user to org_user”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Skipping migration condition not fulfilled” logger=migrator id=“copy data account_user to org_user”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Ldap enabled, reading config file” logger=ldap file=/etc/grafana/ldap.toml
t=2017-04-26T11:48:52+0800 lvl=info msg=“Starting plugin search” logger=plugins
t=2017-04-26T11:48:52+0800 lvl=info msg=“Registering plugin” logger=plugins name=“Datatable Panel”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Registering plugin” logger=plugins name=“Pie Chart”
t=2017-04-26T11:48:52+0800 lvl=info msg=“Registering plugin” logger=plugins name=Splunk
t=2017-04-26T11:48:52+0800 lvl=info msg=“Registering plugin” logger=plugins name=Histogram
t=2017-04-26T11:48:52+0800 lvl=info msg=“Initializing Alerting” logger=alerting.engine
t=2017-04-26T11:48:52+0800 lvl=info msg=“Initializing CleanUpService” logger=cleanup
