Problem with Postgres configuration
Grafana Version 10.1.4 on SLES 15
Set up Postgresql as a database
Editing the grafana.ini file
  • What happened?
In the logs, I see:
Oct 13 14:11:29 dashboards grafana[13116]: Error: ✗ failed to connect to database: parse "postgresql://grafana:pass@localhost/grafana": invalid port ":8T])." after host
Successful connection
# Either "mysql", "postgres" or "sqlite3", it's your choice
type = postgres
host = <IP>:5432
name = grafana
user = grafana
# If the password contains # or ; you have to wrap it with triple quotes. Ex """#password;"""
password = pass
# Use either URL or the previous fields to configure the database
# Example: mysql://user:secret@host:port/database
url = postgres://grafana:pass@<IP>:5432/grafana
