Linux version 5.15.93-rockchip64 (armbian)
Grafana v9.2.4 -
Display Influx time series as stacked bars -
Using the time series panel with this query:
fields = ["chaudiere", "cumulus", "VMC", "garage", "piscine"]
from(bucket: "iota-autogen")
|> filter(fn: (r) => r["_measurement"] == "energy")
|> filter(fn: (r) => contains(value: r._field, set: fields))
|> drop(columns: ["device"])
|> fill(value: 0.0)
|> aggregateWindow(every: ${kWh_interval}, fn: sum )
- What happened?
When selecting Style: “Bars” and Stack series: “Normal” in the panel options, one of the series (cumulus) disappears. Its points are there, its tooltip works, but there is no visible bar.
When using Stack series: Off or 100% the display is as expected
I expected to get all series displayed a color-filled bars, stacked. -
"datasource": {
"uid": "TNIAL2DVz",
"type": "influxdb"
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "bars",
"lineInterpolation": "stepBefore",
"barAlignment": 0,
"lineWidth": 2,
"fillOpacity": 100,
"gradientMode": "none",
"spanNulls": false,
"showPoints": "auto",
"pointSize": 5,
"stacking": {
"mode": "normal",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"links": [],
"min": 0,
"unit": "kwatth"
"overrides": [
"matcher": {
"id": "byName",
"options": "VMC"
"properties": [
"id": "color",
"value": {
"fixedColor": "orange",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "chaudiere"
"properties": [
"id": "color",
"value": {
"fixedColor": "rgb(138, 67, 68)",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "garage"
"properties": [
"id": "color",
"value": {
"fixedColor": "rgb(143, 143, 143)",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "piscine"
"properties": [
"id": "color",
"value": {
"fixedColor": "semi-dark-blue",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "cumulus energy"
"properties": [
"id": "color",
"value": {
"fixedColor": "transparent",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "cumulus"
"properties": [
"id": "color",
"value": {
"fixedColor": "dark-red",
"mode": "fixed"
"gridPos": {
"h": 7,
"w": 11,
"x": 11,
"y": 14
"id": 9,
"interval": "30m",
"options": {
"tooltip": {
"mode": "single",
"sort": "none"
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
"pluginVersion": "9.2.3",
"targets": [
"datasource": {
"type": "influxdb",
"uid": "TNIAL2DVz"
"alias": "$col",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"orderByTime": "ASC",
"policy": "default",
"query": "fields = [\"chaudiere\", \"cumulus\", \"VMC\", \"garage\", \"piscine\"]\n\nfrom(bucket: \"iota-autogen\")\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\n |> filter(fn: (r) => r[\"_measurement\"] == \"energy\")\n |> filter(fn: (r) => contains(value: r._field, set: fields))\n |> drop(columns: [\"device\"])\n |> fill(value: 0.0)\n |> aggregateWindow(every: ${kWh_interval}, fn: sum )\n",
"rawQuery": true,
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"title": "Infrastructure",
"transformations": [],
"type": "timeseries"
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us No errors in the logs
No
Thanks,
Franck
