I converted the old graph visualization to the new time series.
somehow the two negative bars are not playing nice. if I hide one of them the visualization works but with both of them together, one is not showing the bar.
The tooltip is showing the missing bar.
The visualization is showing two stacks, A (normal and low use) and C (normal and low delivery)
Please help!
Grafana 8.0.2, part of Home Assistant Add-on Link to add-on page
Json below
"annotations": {
"list": [
"builtIn": 1,
"datasource": "-- Grafana --",
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"type": "dashboard"
"editable": true,
"gnetId": null,
"graphTooltip": 0,
"id": 5,
"links": [],
"panels": [
"aliasColors": {
"Low Tariff": "#614d93",
"Low Tariff Use": "semi-dark-purple",
"Low Tariff delivery": "light-purple",
"Nett Electricity": "dark-orange",
"Normal Tariff": "#f4d598",
"Normal Tariff Use": "light-orange",
"Normal Tariff delivery": "super-light-orange",
"kWh.difference": "#0a50a1"
"bars": true,
"dashLength": 10,
"dashes": false,
"datasource": "InfluxDB",
"description": "",
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 12,
"w": 9,
"x": 0,
"y": 0
"hiddenSeries": false,
"hideTimeOverride": true,
"id": 4,
"interval": null,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": true,
"values": true
"lines": false,
"linewidth": 1,
"links": [],
"nullPointMode": "null",
"options": {
"alertThreshold": false
"percentage": false,
"pluginVersion": "8.0.2",
"pointradius": 5,
"points": false,
"renderer": "flot",
"seriesOverrides": [
"$$hashKey": "object:1183",
"alias": "Low Tariff delivery",
"stack": "C"
"$$hashKey": "object:1203",
"alias": "Normal Tariff delivery",
"stack": "C"
"$$hashKey": "object:286",
"alias": "Nett Electricity",
"bars": false,
"fillGradient": 0,
"points": true,
"stack": false
"spaceLength": 10,
"stack": true,
"steppedLine": false,
"targets": [
"alias": "Normal Tariff Use",
"groupBy": [
"params": [
"1d"
"type": "time"
"params": [
"previous"
"type": "fill"
"hide": false,
"measurement": "kWh",
"orderByTime": "ASC",
"policy": "default",
"query": "SELECT last(\"value\") - first(\"value\") FROM \"kWh\" WHERE (\"entity_id\" = 'energy_consumption_tarif_2') AND $timeFilter GROUP BY time(1w)",
"rawQuery": true,
"refId": "B",
"resultFormat": "time_series",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"type": "difference"
"tags": [
"key": "entity_id",
"operator": "=",
"value": "power_consumption_normal"
"alias": "Low Tariff Use",
"groupBy": [
"params": [
"1d"
"type": "time"
"params": [
"previous"
"type": "fill"
"hide": false,
"query": "SELECT last(\"value\") - first(\"value\") FROM \"kWh\" WHERE (\"entity_id\" = 'energy_consumption_tarif_1') AND $timeFilter GROUP BY time(1w)\n",
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"value": "power_consumption_low"
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": false,
"query": "SELECT (last(\"value\") - first(\"value\"))*-1 FROM \"kWh\" WHERE (\"entity_id\" = 'energy_production_tarif_1') AND $timeFilter GROUP BY time(1w)",
"rawQuery": true,
"refId": "C",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"value": "energy_production_tarif_1"
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": false,
"query": "SELECT (last(\"value\") - first(\"value\"))*-1 FROM \"kWh\" WHERE (\"entity_id\" = 'energy_production_tarif_2') AND $timeFilter GROUP BY time(1w)",
"rawQuery": true,
"refId": "D",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"datasource": "__expr__",
"expression": "$A+$B+$C+$D",
"hide": false,
"refId": "Nett Electricity",
"type": "math"
"thresholds": [],
"timeFrom": "1y",
"timeRegions": [],
"timeShift": "1h",
"title": "Electricity Use past year (Graph)",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"transparent": true,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:79",
"format": "kwatth",
"label": "",
"logBase": 1,
"max": null,
"min": null,
"show": true
"$$hashKey": "object:80",
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"yaxis": {
"align": false,
"alignLevel": null
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "bars",
"fillOpacity": 100,
"gradientMode": "none",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "never",
"spanNulls": true,
"stacking": {
"group": "A",
"mode": "normal"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "kwatth"
"overrides": [
"matcher": {
"id": "byName",
"options": "Low Tariff Use"
"properties": [
"id": "color",
"value": {
"fixedColor": "semi-dark-purple",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "Low Tariff delivery"
"properties": [
"id": "color",
"value": {
"fixedColor": "light-purple",
"mode": "fixed"
"id": "custom.stacking",
"value": {
"group": "C",
"mode": "normal"
"matcher": {
"id": "byName",
"options": "Normal Tariff Use"
"properties": [
"id": "color",
"value": {
"fixedColor": "light-orange",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "Normal Tariff delivery"
"properties": [
"id": "color",
"value": {
"fixedColor": "super-light-orange",
"mode": "fixed"
"value": {
"group": "C",
"mode": "normal"
"matcher": {
"id": "byName",
"options": "Nett Electricity"
"properties": [
"id": "custom.drawStyle",
"value": "points"
"id": "custom.showPoints",
"value": "always"
"value": {
"group": false,
"mode": "none"
"id": "color",
"value": {
"fixedColor": "dark-orange",
"mode": "fixed"
"gridPos": {
"h": 12,
"w": 9,
"x": 9,
"y": 0
"id": 5,
"interval": null,
"links": [],
"options": {
"legend": {
"calcs": [
"sum"
"displayMode": "list",
"placement": "bottom"
"tooltip": {
"mode": "multi"
"targets": [
"groupBy": [
"params": [
"1d"
"type": "time"
"params": [
"previous"
"type": "fill"
"hide": false,
"rawQuery": true,
"refId": "B",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"groupBy": [
"params": [
"1d"
"type": "time"
"params": [
"previous"
"type": "fill"
"hide": false,
"rawQuery": true,
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": false,
"rawQuery": true,
"refId": "C",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": false,
"rawQuery": true,
"refId": "D",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [],
"tags": [
"key": "entity_id",
"operator": "=",
"hide": false,
"type": "math"
"timeFrom": "1y",
"timeShift": "1h",
"title": "Electricity Use past year (time series)",
"type": "timeseries"
"schemaVersion": 30,
"style": "dark",
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-6h",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "Solar",
"uid": "GDQjtCZRk",
"version": 4
