Sending one simple trace to tempo via http
Hi all,
i want to run a simple prototype with Grafana Tempo (Grafana Cloud). Ideally i would like to use the Opentelemetry SDK on node.js and export Traces/Spans directly from application level to Tempo. But it does not work so far, so therefore i would like to see if there is a simple way through http to send a sample trace.
Is there any simple sample how a curl / postmen request to tempo should look like? Then i should be able to instrument and export my app.
Best,
Django
Grafana Cloud Traces currently will only accept traces in the OTel Proto format over GRPC. It does not accept http/json.
However, I do know that there was work being into creating an http endpoint for traces. Pinging
@gouthamvegrafana who is involved in that work.
I see, thanks.
I finally figured out what went wrong with the GRPC case and node.js grpc exporter sdk. It does not support headers, you have to use environment variables (process.env.OTEL_EXPORTER_OTLP_HEADERS) in order to forward them.
Some example for the community, i saw some have been struggling with the same issue. This worked for me. Side note, the library batches/queues request, so you have to create a bit more traffic (in case you just prototype, like i did).
process.env.OTEL_EXPORTER_OTLP_HEADERS = `Authorization=Basic ${Buffer.from(`${USER_ID}:${API_KEY}`).toString('base64')}`
const { BasicTracerProvider, SimpleSpanProcessor, AlwaysOnSampler, ConsoleSpanExporter,} = require('@opentelemetry/sdk-trace-base');
const opentelemetry = require('@opentelemetry/api');
const { OTLPTraceExporter } =  require('@opentelemetry/exporter-trace-otlp-grpc');
const grpc = require('@grpc/grpc-js');
const provider = new BasicTracerProvider({
  sampler: new AlwaysOnSampler()
const collectorOptions = {
    url: 'https://tempo-eu-west-0.grafana.net:443',
    credentials: grpc.credentials.createSsl(),
const exporter = new OTLPTraceExporter(collectorOptions);
provider.addSpanProcessor(new SimpleSpanProcessor(new ConsoleSpanExporter()));
provider.addSpanProcessor(new SimpleSpanProcessor(exporter));
provider.register();
const tracer = opentelemetry.trace.getTracer('example-basic-tracer-node');
Hope that helps
Why you can’t use grpc metadata = headers? @opentelemetry/exporter-trace-otlp-grpc - npm
Thanks, that works indeed as well :+1:
I just went from http exporter to grpc exporter and relied on the headers.
To close out on the HTTP format, we recommend using the OTLP Gateway which supports HTTP.
See: Sending data using OpenTelemetry Protocol (OTLP) | Grafana Cloud documentation
