Scripted dashboard v16
Could You please update the example scripted dashboards to the latest version?
I cannot use the gridpos (it’s getting ignored) with the current scripted.js example.
Using the dashboard.panels.push method is pretty undocumented.
Hi jangaraj,
Thanks for the answer.
However, I don’t really understand, what is unsupported. The latest Grafana documentation has itself a “Scripted Dashboard” topic, where the gridpos usage is documented, but there is isn’t a full script which could be used as an example.
Anyway, I’m going to check out the tool on the link You have posted, and thanks again for the prompt answer.
