Same query in grafana and prometheus returns different response
Dear community ,
I am facing an issue in grafana query that when i use same query in grafana and promethus the response is different. In grafana am seeing two responses where as in prometheus am seeing single response. And my expectation is also should get single reponse for the query.
Query :
bgp_rib__bgp_rib_afi_safis_afi_safi_ipv4_unicast_loc_rib_num_routes{host=“worker-node-1”}
Grafana Returns:
bgp_rib__bgp_rib_afi_safis_afi_safi_ipv4_unicast_loc_rib_num_routes{bgp_rib_afi_safis_afi_safi__afi_safi_name=“IPV4_UNICAST”, container=“telegraf”, device=“localhost”, endpoint=“metrics”, host=“worker-node-1”, instance=“172.16.122.2:9012”, job=“crpd-prometheus”, namespace=“kube-system”, path ="sensor_1000:/bgp-rib/:/bgp-rib/:rpd ", pod=“kube-crpd-worker-ds-j5xtb”, service=“crpd-prometheus”, system_id=“worker-node-1”}
bgp_rib__bgp_rib_afi_safis_afi_safi_ipv4_unicast_loc_rib_num_routes{bgp_rib_afi_safis_afi_safi__afi_safi_name=“IPV4_UNICAST”, container=“telegraf”, device=“localhost”, endpoint=“metrics”, host=“worker-node-1”, instance=“172.16.122.2:9012”, job=“crpd-prometheus”, namespace=“kube-system”, path ="sensor_1001:/bgp-rib/:/bgp-rib/:rpd ", pod=“kube-crpd-worker-ds-j5xtb”, service=“crpd-prometheus”, system_id=“worker-node-1”}
Prometheus response:
bgp_rib__bgp_rib_afi_safis_afi_safi_ipv4_unicast_loc_rib_num_routes{bgp_rib_afi_safis_afi_safi__afi_safi_name=“IPV4_UNICAST”, container=“telegraf”, device=“localhost”, endpoint=“metrics”, host=“worker-node-1”, instance=“172.16.122.2:9012”, job=“crpd-prometheus”, namespace=“kube-system”, path=“sensor_1001:/bgp-rib/:/bgp-rib/:rpd”, pod=“kube-crpd-worker-ds-j5xtb”, service=“crpd-prometheus”, system_id=“worker-node-1”}
Are you running a query in dashboard or explore? Could you maybe share the query & response from Query/Explore Inspector?
