Good afternoon.
I have Loki version 3.2.1 configured with my Amazon S3. It saves the data in the root of my project, but I want it to save it inside a specific folder, for example, /logs/, but it’s not working.
This is the Loki code:
auth_enabled: false
server:
http_listen_port: 3100
log_level: warn
grpc_listen_port: 9095
common:
path_prefix: /loki
storage:
s3:
bucketnames: ${S3_BUCKET_NAME}
region: ${AWS_REGION}
access_key_id: ${AWS_ACCESS_KEY_ID}
secret_access_key: ${AWS_SECRET_ACCESS_KEY}
replication_factor: 1
ring:
kvstore:
store: inmemory
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
storage_config:
aws:
s3: s3://${S3_BUCKET_NAME}
s3forcepathstyle: true
boltdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/boltdb-cache
limits_config:
allow_structured_metadata: false
reject_old_samples: true
max_cache_freshness_per_query: 10m
max_query_parallelism: 32
max_entries_limit_per_query: 1000001
ingestion_rate_mb: 15
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
chunk_idle_period: 1m
chunk_target_size: 1572864
chunk_retain_period: 1m
compactor:
working_directory: /loki/compactor
query_range:
align_queries_with_step: true
max_retries: 5
parallelise_shardable_queries: true
table_manager:
retention_deletes_enabled: true
retention_period: 168h
query_scheduler:
max_outstanding_requests_per_tenant: 1000```
