Hi everyone,
I’ve been trying to resolve an issue, but haven’t had any success so far. My goal is to save the logs to an S3 bucket (while ensuring they’re also accessible for reading), but the only file that seems to be saved in the bucket is loki_cluster_seed.json.
I can view the logs in Grafana, which indicates that Loki is storing them locally, but I need them saved to S3 as well. I’ve included my configuration below. Any help would be greatly appreciated. Thanks in advance!
auth_enabled: false
server:
http_listen_port: 3100
common:
path_prefix: /tmp/loki
replication_factor: 1
ring:
kvstore:
store: memberlist
schema_config:
configs:
store: tsdb
object_store: aws
schema: v13
index:
prefix: index_
period: 24h
storage_config:
tsdb_shipper:
active_index_directory: /tmp/tsdb-index
cache_location: /tmp/tsdb-cache
cache_ttl: 24h
aws:
s3: s3://<access-key>:<secret-key>@region
bucketnames: bucket-name
