I use Grafana 5.4.3 and I have a issue.
The row panel does not update after select a variable. I see here( Row panel does not update variables/templating values · Issue #15133 · grafana/grafana · GitHub) this problem is solved in 6.0 version but not in 5.4.3.
How to solve this ?
After click on the row, it’s ok
Regards
