For example, I have three row and one variable in my dashboard.
The variable is Http request uri. I want to move this variable into row as name of ’Web‘. Because this variable didn’t have any relationship for other row.
But I didn’t know how to do this. Please give me some help, thanks.
easy.
if the variable name = http
just go to row settings, change the title to “Web $http”
and it will show up like “Web /addGoods”
example
variable name = metric
result
sorry,I may not have described it clearly.
I’m not trying to concatenate the variable to the row’s name, I want to move the whole variable inside the row, like this.
did you get the solution i’m facing same issue?
From what I can tell, it can’t be done on current versions of Grafana:
opened 08:20AM - 10 Jun 16 UTC
type/feature-request
area/dashboard/templating
I have the following use case.
- I have a set of nodes that I am monitoring
- Ea… ch nodes is one of a set of node types.
I can create template variables: node_types (containing the different node types) and nodes (containing all nodes of all types).
I want to show a graph for each node, but I want to **group** them by node type. Ideally, I would have a row repeat that repeats over each node type, and then have a panel repeat within the row that repeats over nodes **of that type**. But I don't think I can do this at the moment?
opened 09:45AM - 20 Apr 18 UTC
closed 01:57PM - 20 Apr 18 UTC
type/duplicate
Read before posting:
- Questions should be posted to https://community.grafa… na.com. Please search there and here on GitHub for similar issues before creating a new issue.
- Checkout FAQ: https://community.grafana.com/c/howto/faq
- Checkout How to troubleshoot metric query issues: https://community.grafana.com/t/how-to-troubleshoot-metric-query-issues/50
Please include this information:
### What Grafana version are you using?
5.0.4
### What datasource are you using?
InfluxDB
### What OS are you running grafana on?
SLES 12
### What did you do?
I tried to Build a Dynamical Dashboard, where i want to all Services from Multiple Hosts.
i repeat every Row by hostname and in this row i repeat a Panels by Measurement.
### What was the expected result?
i hope to get all services from a Host in a row
### What happened instead?
i get all measurements from all Hosts in a Row
### If related to metric query / data viz:
Variable
$hostname | SELECT Domain1.global_id as fqdn FROM Domain1 WHERE productive = 1
$service | show measurements where HOSTNAME =~ /$hostname$/
Panel Query
SELECT /value|max/ FROM /$service$/ WHERE "HOSTNAME" =~ /^$hostname$/ AND $timeFilter GROUP BY HOSTNAME
When i select multiple Hosts Windows,Unix etc... i get many empty panels in row with measuremnts which are not releated to the selected Hosts.
So i Suggest it would be great to get aanother template variable for Rows so i can work with multple Hosts and Services.
