Template variables
Hi, I am kinda new to grafana.I have created a dashboard and i have 5 template variables of which 3 are common for all the graphs,but the remaining 2 template variables is needed for particulars graphs.Is there anyway can i move the the last 2 template variables just above these 2 graphs,rather than be in the top of all graphs.I want the user to select these 2 variables for these 2 graphs and use it.
As far as I know the templates cannot be moved to a different row (it will be in the top always). Whereas, you can change the order in which the templates are displayed from left to right by using arrows in templating option. A habit that I’ve cultivated while creating dashboards is to use description section in the panel to explain which templates work on that panel. Not a very convenient way, but a good one to avoid confusion.
