Template Variable Positioning
Is there a way to make the template variables drag-able like the panels are? I’d like to be able to drag or hard code each variable to a different spot on the dashboard. Preferably close to the panel that it corresponds to. This isn’t currently supported, so does anyone have a general idea of what i’d have to modify in the frontend to make this work?
Dear @grafanaflow,
we are also looking for that and started collecting some resources around that topic on…
With kind regards,
Andreas.
