Creating variables panel instead of top row
Hello, this is my first post.
I’m working on a Grafana dashboard where I’m using several variables. By default, these variables appear at the top of the dashboard where they can be managed.
However, I would prefer to have more control over the positioning of these variable controls. Specifically, I’d like to embed them within a movable panel on the dashboard itself, rather than having them fixed at the top.
Is this possible, and if so, how can I achieve it?
I dont know if you can move the original variables at the top, but you can create a panel and put them wherever you need:
