Hello, I misconfigured dashboard JSON and now it does not load and shows error. The problem is that I even cannot get to dashboard settings to see versions. How can I fix JSON in such broken dashboard?
You can access the data column on the Grafana DB to recover your dashboard (using sqllite).
Hope it helps.
Good Luck
