What is the procedure to request the Discrete panel be added, so published snapshots can present graphs of that type? I tried sharing a dashboard snapshot, and for the Discrete graph I get the message “Unknown panel type: natel-discrete-panel”
I would think adding the major graph types that aren’t included by default in the app, such as Discrete and Pie Chart would be useful.
Thanks
I added a whole bunch of plugins to the snapshot server. Here is a snapshot with the Diagram panel:
https://snapshot.raintank.io/dashboard/snapshot/NzsCBZ7bXhnMTaWbrakP6btrON7IwqbD
Unfortunately, it looks like the discrete panel has not added support for snapshots (see the docs for details). You could open an issue for it on the plugin GitHub repo: https://github.com/NatelEnergy/grafana-discrete-panel/issues
