Grafana v9.3.0 -
I’ve created a custom dashboard variable$queueby using the following query:
label_values({__name__=~"redis_queue_.*"},__name__)
The result of this query is a list of all metrics that start with the redis_queue_.
This variable is a multi-select. What I want to do is to create a repeatable panel based on the following expression:
sum($queue)
I’ve created a Time Series panel and applied said expression. I’ve also configured repeat settings to horizontal, two per row. -
What happened?
When I select only one value from a dropdown, everything is fine. However, if I select multiple values, I get the following error:
422: error when executing query="sum((redis_queue_messages|redis_queue_questions))" on the time range (start=1681985985000, end=1681986885000, step=15000): cannot recognize "|redis_queue_messages))"; unparsed data: "redis_queue_messages|redis_queue_questions))"
Each panel should display a sum of values for each selected value from the$queuevariable. In the case above, I was expecting to get two panels, each showing a sum ofredis_queue_messagesandredis_queue_questionsseparately.
So, I need to find a way to repeat panels and do a sum per selected value, not of all values at once. How can I achieve this?
