Rendering panel inside App plugin
I am looking for a way to render panel (eq. graph, just as in dashboard), inside the App plugin - couldn’t find any. Any pointers to possible solution are most welcome.
Hello @miroslavfoltyn64
If you would like to have panel as acomponent in your app,
this example may help you:
I have here an app with panel and datasource.
Regards,
V.
