Hi im trying to create some basic table panel but for some reason
the where time clause is always set to some time.
"SELECT * FROM “Innovi” WHERE time >= 1502202318180ms and time <= 1502281491056ms"
How can i remove the default time clause.
if you click the query hamburger menu (the bars icon next to trash icon), then switch query to raw mode. Removing time range is 99.9% a very bad idea but if you want to
