I’m trying to configure Loki Recording rules, sending metrics to Prometheus write endpoint.
Loki (distributed Mode) and Prometheus are deployed via helm.
Below is the simple rules configured,
interval: 1m
rules:
- record: testlog_7thApril
expr: |
count_over_time({job="test"}[1m])
I’m trying to load rules into Rules S3 via
https://loki-test.abc.com/loki/api/v1/rules/my_namespace
When I try to get rules via loki endpoint -
I’m able to see rules configured, same thing is visible in GrafanaUI aswell under datasource managed recording rule
Ruler configuration passed via loki settings -
loki:
ruler:
storage:
type: s3
s3:
bucketnames: loki-123-test-west-test
region: us-west-2
s3forcepathstyle: true
rule_path: /rules # Temporary path to store rule files
wal:
dir: /var/loki/ruler-wal
evaluation_interval: 2m
ring:
kvstore:
store: memberlist
enable_api: true
enable_sharding: true
remote_write:
enabled: true
config_refresh_period: 10s
add_org_id_header: true # true
clients:
- url: http://prometheus-test-server.prometheus-test.svc.cluster.local:80/api/v1/write #"https://prometheus-test.abc.com/api/v1/write"
remote_timeout: 30s
send_exemplars: false
send_native_histograms: false
round_robin_dns: false
# write_relabel_configs:
# - source_labels: [__name__]
# target_label: source
# replacement: loki_recording_rules
# queue_config:
# capacity: 10000 # 500
# max_shards: 50 # 100
# min_shards: 1
# max_samples_per_send: 10000
# batch_send_deadline: 5s
# evaluation:
# mode: remote
# query_frontend:
# address: <QF_ADDRESS>
Query -
- I’m unable to see metric -testlog_7thApril in Prometheus. its says NODATA, which means either loki is not sending metrics or prometheus is unable to receive metrics.
- looked into all possible workaround, nothing works,
- Unfortunatly, I don’t see any logs related to remote_write either in loki ruler/prometheus/
Please Assist,
Thanks Much for the support.
