Loki Ruler and write to prometheus not working
I am using the prometheus-community/kube-prometheus-stack helm chart for grafana-prometheus stack and the grafana/loki helm chart in simple scalable mode.
I am trying to use the recording rule feature in loki to pre-compute the count from a query and store it as a metric. This is my loki helm chart values:
loki:
  auth_enabled: false
  commonConfig:
    replication_factor: 3
#    heartbeat_timeout: 10m
  server:
    http_server_read_timeout: 600s
  limits_config:
    max_query_length: 0h
    query_timeout: 600s
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  storage:
    type: s3
    bucketNames:
      chunks: "chunks"
      #ruler: "ruler"
      admin: "admin"
  storage_config:
    aws:
      s3: s3://eu-central-1
      bucketnames: gis-malz-prod-grafana-loki-chunk-store
      sse:
        type: "SSE-S3"
  ingester:
    chunk_encoding: snappy
    chunk_target_size: 1572864
    max_chunk_age: 1h
    chunk_idle_period: 1h
  tracing:
    enabled: true
  querier:
    # Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
    max_concurrent: 2
  rulerConfig:
    rule_path: /rules  # Path to store rules locally (used when storage type is "filesystem")
    evaluation_interval: 1m
    ring:
      kvstore:
        store: "inmemory"  # Store used for coordination of rulers
    storage:
      type: local
      local:
        directory: /rules
    enable_api: true
    remote_write:
      enabled: true
      client:
        #url: 'http://prometheus-operated.monitoring.svc.cluster.local/api/v1/write'
        url: 'https://gris.cloud.syngenta.org/prometheus/api/v1/write'
#    rule_files:
#      - /rules/rules.yaml
persistence:
  enabled: true
  accessModes:
    - ReadWriteOnce
extraObjects:
  - apiVersion: v1
    kind: ConfigMap
    metadata:
      labels:
    data:
      rules.yaml: |-
        groups:
          - name: geoserver_web_internal
            rules:
              - record: job:requests:geoserver_web_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/geoserver/web" [1m])
          - name: geoserver_apis_internal
            rules:
              - record: job:requests:geoserver_api_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/geoserver/gris" [1m])
          - name: fbm_internal
            rules:
              - record: job:requests:fbm_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/fbm/v1" [1m])
          - name: crop_rotation_internal
            rules:
              - record: job:requests:crop_rotation_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/processes/croprotation" [1m])
          - name: publishing_api_internal
            rules:
              - record: job:requets:publishing_api_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/api" [1m])
          - name: catalog_internal
            rules:
              - record: job:requests:catalog_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/catalog" [1m])
          - name: datafactory_ui_internal
            rules:
              - record: job:requests:datafactory_ui_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/datafactory-ui" [1m])
          - name: datafactory_admin_internal
            rules:
              - record: job:requests:datafactory_admin_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/df-admin" [1m])
          - name: airflow_internal
            rules:
              - record: job:requests:airflow_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/datafactory" [1m])
          - name: notificaton_api_internal
            rules:
              - record: job:requests:notification_api_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/notification" [1m])
          - name: ecm_internal
            rules:
              - record: job:requests:ecm_internal
                expr: count_over_time({__aws_s3_lb="malz-prod"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) https://gris.cloud.syngenta.org:443/ecm" [1m])
          - name: geoserver_web_external
            rules:
              - record: job:requests:geoserver_web_external
                expr: count_over_time({filename="/var/log/nginx/access.log"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) /geoserver/web" [1m])
          - name: geoserver_apis_external
            rules:
              - record: job:requests:geoserver_api_external
                expr: count_over_time({filename="/var/log/nginx/access.log"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) /geoserver/gris" [1m])
          - name: fbm_external
            rules:
              - record: job:requests:fbm_external
                expr: count_over_time({filename="/var/log/nginx/access.log"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) /fbm/v1" [1m])
          - name: crop_rotation_external
            rules:
              - record: job:requests:crop_rotation_external
                expr: count_over_time({filename="/var/log/nginx/access.log"} | label_format __stream_shard__="", detected_level="" |~ "(GET|POST) /processes/croprotation" [1m])
gateway:
  ingress:
    enabled: true
    ingressClassName: 'alb'
    annotations:
      kubernetes.io/ingress.class: alb
      alb.ingress.kubernetes.io/load-balancer-name: malz-prod
      alb.ingress.kubernetes.io/load-balancer-attributes: idle_timeout.timeout_seconds=120
      alb.ingress.kubernetes.io/listen-ports: '[{"HTTPS":443}, {"HTTP":80}]'
      alb.ingress.kubernetes.io/certificate-arn: "arn:aws:acm:eu-central-1:********:certificate/aeca61e7-7380-4efb-b97d-f93c3bd4b42d"
      alb.ingress.kubernetes.io/ssl-redirect: '443'
      alb.ingress.kubernetes.io/backend-protocol: HTTP
      alb.ingress.kubernetes.io/healthcheck-interval-seconds: "15"
      alb.ingress.kubernetes.io/healthcheck-path: "/loki/ready"
      alb.ingress.kubernetes.io/healthcheck-port: traffic-port
      alb.ingress.kubernetes.io/healthcheck-timeout-seconds: "5"
      alb.ingress.kubernetes.io/healthy-threshold-count: "2"
      alb.ingress.kubernetes.io/unhealthy-threshold-count: "2"
      alb.ingress.kubernetes.io/success-codes: 200,201
      alb.ingress.kubernetes.io/target-group-attributes: deregistration_delay.timeout_seconds=30
      alb.ingress.kubernetes.io/group.name: albintprod
      alb.ingress.kubernetes.io/scheme: internal
      alb.ingress.kubernetes.io/target-type: ip
    hosts:
      - host: gris.cloud.syngenta.org
        paths:
          - path: /loki
            pathType: Prefix
serviceAccount:
  create: true
  imagePullSecrets: []
  annotations:
    "eks.amazonaws.com/role-arn": "arn:aws:iam::**********:role/gis-prod-pods-RW-role"
  automountServiceAccountToken: true
backend:
  replicas: 2
#  extraVolumes:
#    - name: loki-rules
#      configMap:
#        name: loki-recording-rules
#  extraVolumeMounts:
#      mountPath: /recording-rules
read:
  replicas: 3
  extraVolumes:
    - name: loki-rules
      configMap:
  extraVolumeMounts:
    - name: loki-rules
      mountPath: /rules
write:
  replicas: 2
  extraVolumes:
    - name: loki-rules
      configMap:
  extraVolumeMounts:
    - name: loki-rules
      mountPath: /rules
sidecar:
  image:
    repository: kiwigrid/k8s-sidecar
    tag: 1.27.5
    sha: ""
    pullPolicy: IfNotPresent
  resources: {}
  securityContext: {}
  skipTlsVerify: false
  enableUniqueFilenames: false
  readinessProbe: {}
  livenessProbe: {}
  rules:
    enabled: true
    label: name
    labelValue: "loki-recording-rules"
    folder: /rules
    searchNamespace: null
    watchMethod: WATCH
    resource: configmap
    script: null
    watchServerTimeout: 60
    watchClientTimeout: 60
    logLevel: INFO
This is my prometheus-community/kube-prometheus-stack helm values:
defaultRules:
  create: true
  rules:
    alertmanager: true
    etcd: true
    configReloaders: true
    general: true
    k8s: true
    kubeApiserverAvailability: true
    kubeApiserverBurnrate: true
    kubeApiserverHistogram: true
    kubeApiserverSlos: true
    kubeControllerManager: true
    kubelet: true
    kubeProxy: true
    kubePrometheusGeneral: true
    kubePrometheusNodeRecording: true
    kubernetesApps: true
    kubernetesResources: true
    kubernetesStorage: true
    kubernetesSystem: true
    kubeSchedulerAlerting: true
    kubeSchedulerRecording: true
    kubeStateMetrics: true
    network: true
    node: true
    nodeExporterAlerting: true
    nodeExporterRecording: true
    prometheus: true
    prometheusOperator: true
  appNamespacesTarget: ".*"
env:
  AWS_ROLE_ARN: arn:aws:iam::533792813270:role/gis-prod-grafana-pods-role
  AWS_WEB_IDENTITY_TOKEN_FILE: /var/run/secrets/eks.amazonaws.com/serviceaccount/token
  AWS_REGION: eu-central-1
extraSecretMounts:
  # for AWS EKS (cloudwatch) use the following (see also instruction in env: above)
 - name: aws-iam-token
   mountPath: /var/run/secrets/eks.amazonaws.com/serviceaccount
   readOnly: true
   projected:
     defaultMode: 420
     sources:
       - serviceAccountToken:
           audience: sts.amazonaws.com
           expirationSeconds: 86400
           path: token
##-prometheusOperator-##
## Manages Prometheus and Alertmanager components
prometheusOperator:
  enabled: true
  tls:
    enabled: true
    tlsMinVersion: VersionTLS13
    internalPort: 10250
  admissionWebhooks:
    failurePolicy: ""
    timeoutSeconds: 10
    enabled: true
    caBundle: ""
    annotations: {}
    #   argocd.argoproj.io/hook: PreSync
    #   argocd.argoproj.io/hook-delete-policy: HookSucceeded
    patch:
      enabled: true
      image:
        registry: registry.k8s.io
        repository: ingress-nginx/kube-webhook-certgen
        tag: v20221220-controller-v1.5.1-58-g787ea74b6
        sha: ""
      resources: {}
      priorityClassName: ""
      annotations: {}
      podAnnotations: {}
      nodeSelector: {}
      affinity: {}
      tolerations: []
      securityContext:
        runAsGroup: 2000
        runAsNonRoot: true
        runAsUser: 2000
        seccompProfile:
          type: RuntimeDefault
    # Security context for create job container
    createSecretJob:
      securityContext:
        allowPrivilegeEscalation: false
        readOnlyRootFilesystem: true
        capabilities:
          drop:
          - ALL
      # Security context for patch job container
    patchWebhookJob:
      securityContext:
        capabilities:
          drop:
          - ALL
    # Use certmanager to generate webhook certs
    certManager:
      enabled: false
      rootCert:
        duration: ""
      admissionCert:
        duration: ""
  namespaces: {}
  denyNamespaces: []
  alertmanagerInstanceNamespaces: []
  alertmanagerConfigNamespaces: []
  prometheusInstanceNamespaces: []
  thanosRulerInstanceNamespaces: []
  # clusterDomain: "cluster.local"
  networkPolicy:
    enabled: false
    flavor: kubernetes
  serviceAccount:
    create: true
  service:
    annotations: {}
    labels: {}
    clusterIP: ""
    nodePort: 30080
    nodePortTls: 30443
    additionalPorts: []
    loadBalancerIP: ""
    loadBalancerSourceRanges: []
    externalTrafficPolicy: Cluster
    type: ClusterIP
    externalIPs: []
  labels: {}
  annotations: {}
  podLabels: {}
  podAnnotations: {}
  kubeletService:
    enabled: true
    namespace: kube-system
  serviceMonitor:
    additionalLabels: {}
    interval: ""
    sampleLimit: 0
    targetLimit: 0
    labelLimit: 0
    labelNameLengthLimit: 0
    labelValueLengthLimit: 0
    scrapeTimeout: ""
    selfMonitor: true
    metricRelabelings: []
    relabelings: []
  resources:
    limits:
      cpu: 1000m
      memory: 2000Mi
    requests:
      cpu: 100m
      memory: 100Mi
  hostNetwork: false
  nodeSelector: {}
  tolerations: []
  affinity: {}
  dnsConfig: {}
  securityContext:
    fsGroup: 65534
    runAsGroup: 65534
    runAsNonRoot: true
    runAsUser: 65534
    seccompProfile:
  containerSecurityContext:
    capabilities:
      drop:
      - ALL
  ## Prometheus-operator image
  image:
    registry: quay.io
    repository: prometheus-operator/prometheus-operator
    tag: ""
    sha: ""
  prometheusConfigReloader:
    image:
      registry: quay.io
      repository: prometheus-operator/prometheus-config-reloader
      tag: ""
      sha: ""
    enableProbe: false
    resources:
      requests:
        cpu: 200m
        memory: 50Mi
      limits:
        cpu: 200m
        memory: 50Mi
##-Prometheus-##
prometheus:
  enabled: true
  annotations: {}
  networkPolicy:
    enabled: failure-domain.beta.kubernetes.io/zone
    flavor: kubernetes
  serviceAccount:
    create: true
    annotations: {}
  service:
    annotations: {}
    labels: {}
    clusterIP: ""
    port: 9090
    targetPort: 9090
    externalIPs: []
    nodePort: 30090
    loadBalancerIP: ""
    type: ClusterIP
    additionalPorts: []
    publishNotReadyAddresses: false
    sessionAffinity: ""
    tlsSecretPerReplica:
      enabled: false
      prefix: "prometheus"
  ingress:
    ## If true, Prometheus Ingress will be created
    enabled: true
    ## IngressClassName for Promtheus Ingress.
    ## Should be provided if Ingress is enable.
    ingressClassName: alb
    ## Annotations for Prometheus Ingress
    annotations: {
      alb.ingress.kubernetes.io/backend-protocol: "HTTP",
      alb.ingress.kubernetes.io/group.name: "albintprod",
      alb.ingress.kubernetes.io/listen-ports: '[{"HTTPS":443}, {"HTTP":80}]',
      alb.ingress.kubernetes.io/certificate-arn: "arn:aws:acm:eu-central-1:533792813270:certificate/aeca61e7-7380-4efb-b97d-f93c3bd4b42d",
      #alb.ingress.kubernetes.io/ssl-redirect: '443',
      alb.ingress.kubernetes.io/healthcheck-interval-seconds: "15",
      alb.ingress.kubernetes.io/healthcheck-path: "/",
      alb.ingress.kubernetes.io/healthcheck-port: "traffic-port",
      alb.ingress.kubernetes.io/healthcheck-timeout-seconds: "5",
      alb.ingress.kubernetes.io/healthy-threshold-count: "2",
      alb.ingress.kubernetes.io/load-balancer-name: "malz-prod",
      alb.ingress.kubernetes.io/scheme: "internal",
      alb.ingress.kubernetes.io/success-codes: "200,201",
      alb.ingress.kubernetes.io/target-group-attributes: "deregistration_delay.timeout_seconds=30",
      alb.ingress.kubernetes.io/target-type: "ip",
      alb.ingress.kubernetes.io/unhealthy-threshold-count: "2",
      kubernetes.io/ingress.class: "alb"
    ## Hostnames.
    ## Must be provided if Ingress is enable.
    hosts:
      - gris.cloud.syngenta.org
    ## Path for grafana ingress
    paths:
      - /prometheus
  podSecurityPolicy:
    allowedCapabilities: []
    allowedHostPaths: []
    volumes: []
  serviceMonitor:
    interval: ""
    selfMonitor: true
    sampleLimit: 0
    targetLimit: 0
    labelLimit: 0
    scheme: ""
    tlsConfig: {}
    bearerTokenFile:
    relabelings: []
  prometheusSpec:
    disableCompaction: false
    apiserverConfig: {}
    additionalArgs: []
    scrapeInterval: ""
    scrapeTimeout: ""
    evaluationInterval: ""
    listenLocal: false
    enableAdminAPI: false
    version: ""
    web: {}
    exemplars: ""
    enableFeatures: []
    image:
      registry: quay.io
      repository: prometheus/prometheus
      tag: v2.44.0
      sha: ""
    tolerations: []
    topologySpreadConstraints: []
    alertingEndpoints: []
    externalLabels: {}
    enableRemoteWriteReceiver: true
    replicaExternalLabelName: ""
    replicaExternalLabelNameClear: false
    prometheusExternalLabelName: ""
    prometheusExternalLabelNameClear: false
    externalUrl: "gris.cloud.syngenta.org/prometheus"
    nodeSelector: {}
    secrets: []
    configMaps: []
    query: {}
    ruleNamespaceSelector: {}
    ruleSelectorNilUsesHelmValues: false
    ruleSelector: {}
    serviceMonitorSelectorNilUsesHelmValues: false
    serviceMonitorSelector: {}
    serviceMonitorNamespaceSelector: {}
    podMonitorSelectorNilUsesHelmValues: false
    podMonitorSelector: {}
    podMonitorNamespaceSelector: {}
    probeSelectorNilUsesHelmValues: false
    probeSelector: {}
    probeNamespaceSelector: {}
    scrapeConfigSelectorNilUsesHelmValues: false
    scrapeConfigSelector: {}
    scrapeConfigNamespaceSelector: {}
    retention: 10d
    retentionSize: ""
    tsdb:
      outOfOrderTimeWindow: 0s
    walCompression: true
    paused: false
    replicas: 1
    shards: 1
    logLevel: info
    logFormat: logfmt
    routePrefix: /
    podMetadata: {}
    podAntiAffinity: ""
    podAntiAffinityTopologyKey: kubernetes.io/hostname
    affinity: {}
    remoteRead: []
    # - url: http://remote1/read
    ## additionalRemoteRead is appended to remoteRead
    additionalRemoteRead: []
    remoteWrite: []
    # - url: http://remote1/push
    ## additionalRemoteWrite is appended to remoteWrite
    additionalRemoteWrite: []
    remoteWriteDashboards: false
    resources:
    requests:
      memory: 400Mi
    storageSpec: {}
    volumes: []
    volumeMounts: []
#    additionalScrapeConfigs: |
#      - job_name: 'loki'
#        static_configs:
#          #- targets: ['http://loki-gateway.monitoring.svc.cluster.local']
#          - targets: ['gris.cloud.syngenta.org/loki']
    additionalScrapeConfigsSecret: {}
    additionalPrometheusSecretsAnnotations: {}
    additionalAlertManagerConfigs: []
    additionalAlertManagerConfigsSecret: {}
    additionalAlertRelabelConfigs: []
    additionalAlertRelabelConfigsSecret: {}
    securityContext:
      runAsGroup: 2000
      runAsNonRoot: true
      runAsUser: 1000
      fsGroup: 2000
      seccompProfile:
    thanos: {}
    containers: []
    initContainers: []
    portName: "web"
    arbitraryFSAccessThroughSMs: false
    overrideHonorLabels: false
    overrideHonorTimestamps: false
    ignoreNamespaceSelectors: false
    enforcedNamespaceLabel: ""
    prometheusRulesExcludedFromEnforce: []
    excludedFromEnforcement: []
    queryLogFile: false
    enforcedSampleLimit: false
    enforcedTargetLimit: false
    enforcedLabelLimit: false
    enforcedLabelNameLengthLimit: false
    enforcedLabelValueLengthLimit: false
    allowOverlappingBlocks: false
    minReadySeconds: 0
    hostNetwork: false
    hostAliases: []
  additionalRulesForClusterRole: []
  additionalServiceMonitors: []
  additionalPodMonitors: []
thanosRuler:
  enabled: false
cleanPrometheusOperatorObjectNames: false
extraManifests: []
I dont see any errors in the loki-backend pods related to ruler, but I can see the ruler component is up from the backend pod logs.
Will this metric be available on loki to view? Can prometheus scrape these metrics from Loki?
I have tried the loki remote_write option to write it to the prometheus, that does not show me the new metric in prometheus.
