Loki Recording Rule to Mimir
Hi All,
We are trying to configure loki recording rule to send metrics to mimir backend and view metric via grafana UI.
unforunatly we were not able to setup this asexpected, notsure where we are failing,
belowi is the configuration from loki ruler :
ruler:
    # external_url: http://grafana-test.grafana-test.svc.cluster.local
    enable_api: true
    evaluation_interval: 1m
    poll_interval: 1m
    storage:
      type: s3
      s3:
        bucketnames: loki-7boss-test-west-test
        region: us-west-2
        s3forcepathstyle: true
      # local:
      #   directory: /rules
    rule_path: /rules
    # wal:
    #   dir: /loki/ruler-wal
    # ring:
    #   kvstore:
    #     store: memberlist
    # enable_sharding: true
    # alertmanager_url: http://prometheus-test-alertmanager.prometheus-test.svc.cluster.local:9093
    # enable_alertmanager_v2: true
    remote_write:
      enabled: true
      config_refresh_period: 10s
      add_org_id_header: true  # true
      clients:
        - url: http://mimir-test-distributor.mimir-test.svc.cluster.local:8080/api/v1/push
          remote_timeout: 30s
          send_exemplars: false
          send_native_histograms: false
          round_robin_dns: false
          write_relabel_configs:
            - source_labels: [__name__]
              target_label: source
              replacement: testRule
          # queue_config:
          #   capacity: 10000 # 500
          #   max_shards: 50  # 100
          #   min_shards: 1
          #   max_samples_per_send: 10000
          #   batch_send_deadline: 5s
      # evaluation:
      #   mode: remote
      #   query_frontend:
      #     address: <QF_ADDRESS>
Mimir configuration:
api:
  prometheus_http_prefix: /prometheus
  response_compression_enabled: true
limits:
  out_of_order_time_window: 5m
  ingestion_rate: 10000
  ingestion_burst_size: 200000
serviceAccount:
  # -- Whether to create a service account or not. In case 'create' is false, do set 'name' to an existing service account name.
  create: true
  annotations:
    "eks.amazonaws.com/role-arn": "arn:aws:iam::<11111>:role/mimirServiceAccountRole-testCluster"
alertmanager:
  enabled: false
  persistentVolume:
    enabled: true
    storageClass: mimir-ebs-sc
    accessModes:
      - ReadWriteOnce
    whenDeleted: Delete
    whenScaled: Delete
  replicas: 1
  statefulSet:
    enabled: false
compactor:
  enabled: true
  replicas: 1
  persistentVolume:
    enabled: true
    accessModes:
      - ReadWriteOnce
    whenDeleted: Retain
    whenScaled: Retain
distributor:
  replicas: 3
  replication_factor: 1
  ring:
    kvstore:
      store: memberlist
ingester:
  persistentVolume:
    enabled: true
    size: 2Gi    #   size: 8Gi
    accessModes:
      - ReadWriteOnce
    whenDeleted: Delete
    whenScaled: Retain
  replicas: 1
  lifecycler:
    ring:
      kvstore:
        store: memberlist
  topologySpreadConstraints: {}
  affinity:
    podAntiAffinity:
      requiredDuringSchedulingIgnoredDuringExecution:
        - labelSelector:
            matchExpressions:
              - key: target # support for enterprise.legacyLabels
                operator: In
                values:
                  - ingester
          topologyKey: 'kubernetes.io/hostname'
        - labelSelector:
            matchExpressions:
              - key: app.kubernetes.io/component
                operator: In
                values:
                  - ingester
  zoneAwareReplication:
    enabled: true
  extraArgs:
    "ingester.max-global-series-per-user": 990000
    # - --ingester.max-series-per-user=500000
admin-cache:
  enabled: false
  replicas: 1
chunks-cache:
  enabled: false
  replicas: 1
index-cache:
  enabled: false
  replicas: 1
metadata-cache:
  enabled: false
  replicas: 1
results-cache:
  enabled: false
  replicas: 1
minio:
  enabled: false
mimir:
  structuredConfig:
    common:
      storage:
        backend: s3
        s3:
          endpoint: s3.us-west-2.amazonaws.com
          region: us-west-2
    blocks_storage:
      s3:
        bucket_name: mimir-testcluster-blocks
    alertmanager_storage:
      s3:
        bucket_name: mimir-testcluster-alertmanager
    ruler_storage:
      s3:
        bucket_name: mimir-testcluster-ruler
overrides_exporter:
  replicas: 1
querier:
  replicas: 2
query_frontend:
  replicas: 1
ruler:
  replicas: 2
# kubectl delete statefulset mimir-test-store-gateway -n mimir-test --cascade=orphan
store_gateway:
  persistentVolume:
    enabled: true
    accessModes:
      - ReadWriteOnce
    whenDeleted: Delete
    whenScaled: Retain
  replicas: 2
  affinity:
    podAntiAffinity:
        - labelSelector:
            matchExpressions:
                operator: In
                values:
                  - store-gateway
        - labelSelector:
            matchExpressions:
                operator: In
                values:
                  - store-gateway
    enabled: true
    # topologyKey: 'kubernetes.io/hostname'
nginx:
  replicas: 1
# Grafana Enterprise Metrics feature related
admin_api:
  replicas: 1
gateway:
  replicas: 1
loki recording rule:
interval: 1m
rules:
    - record: avg:execution_time:5m
      expr: |
        avg_over_time(
        {job="test"}
        | logfmt
        | regexp "executionTime: (?P<execution_time>[0-9]+)"
        | unwrap execution_time [5m])
      labels:
        job: test
        environment: dev
loki ruler logs -
I see ruler is evaluation the recording rule, but not sure, whethere its trying to send anything to mimir,
No related logs in mimir,
level=info ts=2025-04-25T13:20:18.225955479Z caller=metrics.go:230 component=ruler evaluation_mode=local org_id=fake latency=fast query=“avg_over_time({job="test"} | logfmt | regexp "executionTime: (?P<execution_time>[0-9]+)" | unwrap execution_time[5m])” query_hash=1335626740 query_type=metric range_type=instant length=0s start_delta=4.447843ms end_delta=4.448034ms step=0s duration=3.318371ms status=200 limit=0 returned_lines=0 throughput=1.4MB total_bytes=4.6kB total_bytes_structured_metadata=912B lines_per_second=34354 total_lines=114 post_filter_lines=114 total_entries=1 store_chunks_download_time=0s queue_time=0s splits=0 shards=0 query_referenced_structured_metadata=false pipeline_wrapper_filtered_lines=0 chunk_refs_fetch_time=2.167259ms cache_chunk_req=0 cache_chunk_hit=0 cache_chunk_bytes_stored=0 cache_chunk_bytes_fetched=0 cache_chunk_download_time=0s cache_index_req=0 cache_index_hit=0 cache_index_download_time=0s cache_stats_results_req=0 cache_stats_results_hit=0 cache_stats_results_download_time=0s cache_volume_results_req=0 cache_volume_results_hit=0 cache_volume_results_download_time=0s cache_result_req=0 cache_result_hit=0 cache_result_download_time=0s cache_result_query_length_served=0s ingester_chunk_refs=0 ingester_chunk_downloaded=0 ingester_chunk_matches=1 ingester_requests=6 ingester_chunk_head_bytes=4.6kB ingester_chunk_compressed_bytes=0B ingester_chunk_decompressed_bytes=0B ingester_post_filter_lines=114 congestion_control_latency=0s index_total_chunks=0 index_post_bloom_filter_chunks=0 index_bloom_filter_ratio=0.00 index_used_bloom_filters=false index_shard_resolver_duration=0s disable_pipeline_wrappers=false has_labelfilter_before_parser=false
ts=2025-04-25T13:20:26.2888288Z caller=memberlist_logger
Can anyone please assist, what are we missing here,
ThanksMuch,
Hi @udayp081198 ,
I’m facing the same issue with our setup. Did you manage to fix this issue?
