I’m trying to figure out why my Loki setup is not running recording rules and not sending the resulting metrics to the Prometheus remote write endpoint. The rules do get added to the /rules directory by the sidecar container, but I don’t see anything related in the logs of the loki container in the loki-backend pod or the loki-sc-rules container, even after enabling debug logging for both. Of course, there are no new metrics either. I’m starting to think that the recording rules might not actually be running on the Loki backend ruler component at all.
I’m using the Loki Helm chart, version 6.25.0 with Flux (S3 bucket and region values redacted).
Any insights would be greatly appreciated; I’ve tried everything in the Grafana forums or Github issues but nothing seems to work.
Loki config:
global:
dnsService: coredns
chunksCache:
enabled: false
resultsCache:
enabled: false
gateway:
enabled: false
test:
enabled: false
lokiCanary:
enabled: false
backend:
extraArgs:
- "-log.level=debug"
sidecar:
rules:
logLevel: DEBUG
loki:
auth_enabled: false
ingester:
chunk_encoding: snappy
storage:
type: s3
limits_config:
volume_enabled: true
query_timeout: 10m
schemaConfig:
configs:
index:
period: 24h
prefix: loki_index_
object_store: s3
schema: v13
store: tsdb
rulerConfig:
remote_write:
enabled: true
clients:
main:
url: http://prometheus.monitoring:9090/api/v1/write
ruler:
enabled: true
persistence:
enabled: true
Prometheus config:
prometheus:
prometheusSpec:
enableRemoteWriteReceiver: true
Some of the dummy rules I tried:
apiVersion: v1
kind: ConfigMap
metadata:
namespace: monitoring
labels:
loki_rule: ""
data:
aaa.yaml: |
groups:
- name: aaa
limit: 10
interval: 1m
rules:
- record: aaa:aaa:rate1m
expr: |
sum(
rate({container="aaa"}[1m])
kind: ConfigMap
metadata:
labels:
loki_rule: ""
data:
aaab.yaml: |
namespace: rules
groups:
- name: aaab
interval: 1m
rules:
- record: aaab:aaab:rate1m
expr: |-
sum(rate({service="aaab"}[1m]))
