Unable to fetch logs in Loki from a remote Promtail agent
We have Loki Server up and running on a Linux Instance as service; I can scrape the logs from localhost using Promtail. I have installed Promtail on another Linux Instance in the same subnet; But when I try to scrape logs from other Linux Instance using Promtail its not working.
I have used below config for Loki:
config:
auth_enabled: false
ingester:
chunk_idle_period: 3m
chunk_block_size: 262144
chunk_retain_period: 1m
max_transfer_retries: 0
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
  ## Different ring configs can be used. E.g. Consul
  # ring:
  #   store: consul
  #   replication_factor: 1
  #   consul:
  #     host: "consul:8500"
  #     prefix: ""
  #     httpclienttimeout: "20s"
  #     consistentreads: true
limits_config:
enforce_metric_name: false
reject_old_samples: true
schema_config:
configs:
store: boltdb
object_store: filesystem
schema: v9
index:
prefix: index_
period: 168h
server:
http_listen_port: 3100
storage_config:
boltdb:
directory: /data/loki/index
filesystem:
directory: /data/loki/chunks
chunk_store_config:
max_look_back_period: 0
table_manager:
retention_deletes_enabled: false
retention_period: 0s
Promtail Config:
[root@ip-172-30-209-119 ~]# cat /usr/local/bin/config-promtail.yml
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
scrape_configs:
  • job_name: test
    static_configs:
    • targets:
      • localhost
        labels:
        job: test-log
        env: dev
        host: localhost
        path: /home/ec2-user/test/*.log
Your problem could be solved?? I have the same problem
