I have kubernetes cluster where promtail is deployed as daemon set this promtail collects the logs fromm the pods running in the cluster, here is the configuration for the promtail I am using:
server:
log_level: info
log_format: logfmt
http_listen_port: 3101
clients:
- url: http://34.68.174.138:3100/loki/api/v1/push
positions:
filename: /run/promtail/positions.yaml
scrape_configs:
# See also https://github.com/grafana/loki/blob/master/production/ksonnet/promtail/scrape_config.libsonnet for reference
- job_name: kubernetes-pods
pipeline_stages:
- cri: {}
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_controller_name
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
action: replace
target_label: __tmp_controller_name
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_name
- __tmp_controller_name
- __meta_kubernetes_pod_name
regex: ^;*([^;]+)(;.*)?$
action: replace
target_label: app
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_instance
- __meta_kubernetes_pod_label_instance
action: replace
target_label: instance
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_component
- __meta_kubernetes_pod_label_component
action: replace
target_label: component
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node_name
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
replacement: $1
separator: /
source_labels:
- namespace
- app
target_label: job
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- action: replace
replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
- action: replace
regex: true/(.*)
separator: /
source_labels:
- __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
- __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
limits_config:
tracing:
enabled: false
Loki is running on a cerntal server with the following configuration:
auth_enabled: false
chunk_store_config:
max_look_back_period: 0s
compactor:
shared_store: filesystem
working_directory: /data/loki/boltdb-shipper-compactor
ingester:
chunk_block_size: 262144
chunk_idle_period: 3m
chunk_retain_period: 1m
lifecycler:
ring:
replication_factor: 1
max_transfer_retries: 0
wal:
dir: /data/loki/wal
limits_config:
enforce_metric_name: false
max_entries_limit_per_query: 5000
reject_old_samples: true
memberlist:
join_members:
- 'loki-memberlist'
schema_config:
configs:
- chunks:
period: 24h
prefix: chunk_loki_
index:
period: 24h
prefix: index_loki_
object_store: gcs
schema: v11
store: boltdb-shipper
server:
grpc_listen_port: 9095
http_listen_port: 3100
storage_config:
boltdb_shipper:
active_index_directory: /data/loki/index
cache_location: /data/loki/index_cache
cache_ttl: 24h
resync_interval: 5s
shared_store: gcs
filesystem:
directory: /data/loki/chunks
gcs:
bucket_name: np-monitoring-infra-loki-us-ct1-gcs
table_manager:
retention_deletes_enabled: false
In the grafana when i query the logs for most of the service I am able to get the logs properly as shown in the below screenshot:
But for a particular service which is generating bulk and lengthy logs I am getting below error
How do i resolve this to be able to properly get the logs?
