Can you share your configuration, please?
Also take a look at the kubernetes_sd_config if you aren’t already using it: Configure Promtail | Grafana Loki documentation
apiVersion: v1
kind: ConfigMap
metadata:
namespace: logging
labels:
app: promtail
data:
region: <REGION_NAME>
stage: test
apiKey: <API_KEY> # Don’t remove complement character(“=”)
instanceUrl: <LOKI_INSTANCE_URL>
lokiInstanceID: <LOKI_INSTACE_ID> # Should be int string example for “1234566”
promtail-config: |
server:
http_listen_port: 0
grpc_listen_port: 0
clients:
- url: https://${INSTANCE_ID}:${API_KEY}@${INSTANCE_URL}/loki/api/v1/push
scrape_configs:
- job_name: vkube-pod-logs
kubernetes_sd_configs:
- role: pod
pipeline_stages:
- docker: {}
relabel_configs:
- source_labels: [__meta_kubernetes_namespace, __meta_kubernetes_pod_label_log_host]
separator: ;
regex: default;loki
action: keep
- source_labels: [__meta_kubernetes_namespace, __meta_kubernetes_pod_name, __meta_kubernetes_pod_uid, __meta_kubernetes_pod_container_name]
action: replace
target_label: __path__
regex: '(.+);(.+);(.+);(.+)'
replacement: '/var/log/pods/$${1}_$${2}_$${3}/$${4}/*.log'
- source_labels: [__meta_kubernetes_pod_name]
target_label: pod
# app name should be equal to deployment name
- source_labels: [__meta_kubernetes_pod_label_app]
target_label: app
- source_labels: [__meta_kubernetes_namespace]
target_label: namespace
- source_labels: [__meta_kubernetes_pod_container_name]
target_label: container
- source_labels: [__meta_kubernetes_pod_uid]
target_label: pod_uid
# Add node name as a label
- source_labels: [__meta_kubernetes_pod_node_name]
target_label: node_name
# Add host IP as a label
- source_labels: [__meta_kubernetes_pod_host_ip]
target_label: host_ip
- source_labels: []
target_label: region
replacement: ${CLUSTER_REGION:-unknown}
action: replace
- source_labels: []
target_label: stage
replacement: ${STAGE:-test}
action: replace
# Drop the 'filename' label
- action: labeldrop
regex: 'filename'
- job_name: vcloud-pod-logs
- role: pod
pipeline_stages:
- docker: {}
relabel_configs:
# Keep all pods in the production namespace
regex: vcloud
action: keep
action: replace
target_label: pod
target_label: app
- source_labels: []
action: replace
- source_labels: []
target_label: stage
action: replace
- action: labeldrop
regex: 'filename'
Thank you.This is the config of promtail.
Don’t see anything obviously wrong, but I would recommend you to try a couple of things:
What do your logs look like? Are logs actually being sent to Loki?
Get rid of all relabel configurations and keep perhaps one, so it’s easier to troubleshoot.
You can use
static_labelsto add arbitrary labels into your log streams, would be a good way to test (see static_labels | Grafana Loki documentation). -
Try to run promtail from cli in debug / inspect mode. See Troubleshooting Promtail | Grafana Loki documentation.
It does look like your logs aren’t being sent at all, so I’d double check and make sure promtail has access to your docker / kubernetes logs.
