I deployed Loki and Promtail using the grafana Helm Chart and I struggle to configure it.
As a simple configuration, I would like to add a specific label (an UUID). To do so, I use the specific yaml :
config:
lokiAddress: http://loki-headless.admin:3100/loki/api/v1/push
snippets:
extraScrapeConfigs: |
- job_name: dashboard
kubernetes_sd_configs:
- role: pod
pipeline_stages:
- docker: {}
- match:
selector: '{container = "dashboard"}'
stages:
- regex:
expression: '(?P<loguuid>[0-9a-f]{8}\b-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-\b[0-9a-f]{12})'
- labels:
loguuid:
Which is deployed with the command:
helm upgrade -install promtail -n admin grafana/promtail -f promtail.yaml
Of course, I still don’t have the label in grafana.
Can someone tell me what I did wrong?
b0b
February 8, 2022, 4:04pm
2
Hi @guillaumegillet ,
I don’t use helm and actually I do not use Promtail, but grafana-agent should use the same config.
This is how my grafana-agent job config looks like. Maybe it helps although it is not a direct comparison to your situation.
positions:
filename: /tmp/positions_pods.yaml
scrape_configs:
- job_name: kubernetes_pods
- role: pod
pipeline_stages:
- docker: {}
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_controller_name
target_label: __service__
- source_labels:
- __meta_kubernetes_pod_node_name
target_label: __host__
- action: labelmap
regex: __meta_kubernetes_pod_label_(app|project|service)
- action: replace
replacement: $1
source_labels:
- name
target_label: job
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
source_labels:
- __meta_kubernetes_pod_name
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
Thx @b0b ,
Unfortunately I am looking to extract something inside the log body. Unless I am wrong, your config only fetch info from kubernetes api
b0b
February 9, 2022, 8:21am
4
Sorry. i don’t know what I thought I was reading… In my head you where trying to add something that was available as Kubernetes metadata.
taksan
March 22, 2022, 9:58pm
5
You are the only person I found having the same issues I was going through, so I suppose others will benefit of the solution:
Thanks to this post on stackoverflow:
https://stackoverflow.com/questions/63414638/promtail-ignores-extrascrapeconfigs
I was able to implement the correct solution for the exact same issue you are having.
Apparently the fact that extraScrapeConfigs is appended to the end of the configuration affects promtail ability to add custom labels. So, instead of using extraScrapeConfigs, use the pipelineStages. On loki-stack 2.2.0, this the configuration that worked for me:
promtail:
enabled: true
pipelineStages:
- cri: {}
- regex:
expression: '^.*[0-9]{4}-[0-9]{2}-[0-9]{2} [0-9]{2}:[0-9]{2}:[0-9]{2},[0-9]{3} (?P<level>[A-Z]+) \[\[(?P<sourcefile>.*)\]\].*'
- labels:
level:
sourcefile:
I hope it helps
