hangon
July 11, 2023, 1:11pm
1
I’m using the latest promtail and loki and trying to use your static_configs example… but I’m not getting the labels pushed to Loki… all I see below
Discovered labels
__address
__path
job
I do not see labels of facility and hostname am I doing something wrong ?
here is my promtail
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: C:\loki\tmp\promtail\positions.yaml
clients:
url: http://localhost:3100/loki/api/v1/push
scrape_configs:
job_name: rfc5424
pipeline_stages:
regex:
expression: ‘.?<(\d+)>(\d+)\s\d±\d±\d+T\d+:\d+:\d+.\d+\S+\s+(\S+)\s+. ’
output:
source_labels: [facility, hostname]
labels:
facility: “${1}”
hostname: “${2}”
static_configs:
targets:
localhost
labels:
job: rfc5424
path : C:\logs\rfc5424*log
My Log format is
<165>1 2003-10-11T22:14:15.003Z mymachine.example.com evntslog - ID47 [exampleSDID@32473 iut=“3” eventSource=“Application” eventID=“1011”] BOMAn application event log entry…
Couple of things:
Your regex doesn’t actually match your log string.
In order to retain something regex you need to use capture groups.
Once you capture something with regex you can then use it as a reference in subsequent pipeline actions.
Your formation is all over the place, so I am not quite sure which part of the log would be facility, so the example below captures hostname only (not tested):
scrape_configs:
- job_name: rfc5424
static_configs:
- targets: localhost
labels:
job: rfc5424
path: C:\logs\rfc5424*log
pipeline_stages:
- regex:
expression: '^\S+ \S+ (?P<hostname>\S+) .*$'
- labels:
hostname:
I would also recommend you to capture the timestamp part and turn that into actual timestamp for the log stream.
hangon
July 12, 2023, 6:50pm
3
First, Thanks for the response… really appreciate it… I tried to acheive in different ways… but I’m still not getting the results I need (may be my understanding is wrong ?)
I tried different ways … here is my config and I’m expecting label “identification” show up in the loki but not working…
server:
grpc_listen_port: 0
positions:
filename: C:\_development\loki\tmp\promtail\positions.yaml
clients:
- url: http://localhost:3100/loki/api/v1/push
scrape_configs:
- job_name: systemx
static_configs:
- targets:
- localhost
labels:
job: varlogs
host: testserver
__path__: C:\_development\logs\rfc5424x\*log
pipeline_stages:
- regex:
- labels:
identification: ${hostname}
Here is the screenshot from the Service Discovery Page where I do not see “Identification”
hangon
July 12, 2023, 7:45pm
4
Finally this is working for me… you have to check it in th Grafana - Datasources - Explore
server:
grpc_listen_port: 0
positions:
clients:
scrape_configs:
- job_name: systemx
static_configs:
- targets:
- localhost
labels:
job: varlogs
host: testserver
pipeline_stages:
- regex:
- labels:
hostname:
