Promtail daemonset relabel_configs does not work
I deployed promtail daemonset in my k8s to collect my application logs.
I want to add some K8S node or pod labels, but when i query logs in grafana, i did not see any k8s labels and only labels in static_configs can be found.
Here is my configmap for promtail, can you help me?
apiVersion: v1
kind: ConfigMap
metadata:
namespace: prod
labels:
app: promtail
data:
promtail.yaml: |
client:
backoff_config:
max_period: 5m
max_retries: 10
min_period: 500ms
batchsize: 1048576
batchwait: 1s
external_labels: {}
timeout: 10s
positions:
filename: /run/promtail/positions.yaml
server:
http_listen_port: 3101
target_config:
sync_period: 10s
scrape_configs:
  • job_name: applogs
    kubernetes_sd_configs:
  • role: node
    relabel_configs:
  • source_labels: [__meta_kubernetes_pod_node_name]
    target_label: node_name
  • source_labels: [__meta_kubernetes_pod_host_ip]
    target_label: node_ip
    static_configs:
  • targets:
  • localhost
    labels:
    job: myapp
    path: /xxx/xxx/xxx/x.log
I am pretty sure the meta labels are only available if you scrape from Kubernetes directly (i.e. not using file targets).
I did not understand what you mean, can you help me check my configmap? or can you give me an example?
See Configuration | Prometheus. Google also returns some examples.
Thanks, i finally solved the problem by adding “config.expand-env” in promtail’s startup paramaters, thus making environment variables valid in its configmap.
