Hi. I am trying to deploy promtail & loki in my minikube setup. I can’t see any labels on loki UI. Attaching my promtail configmap. For loki, I am not using any custom configmap. It uses default settings. Please help
apiVersion: v1
kind: ConfigMap
metadata:
data:
promtail.yaml: |
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://loki:3100/loki/api/v1/push
scrape_configs:
- job_name: kubernetes-pods-name
pipeline_stages:
- docker: {}
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_label_name
target_label: __service__
- source_labels:
- __meta_kubernetes_pod_node_name
target_label: __host__
- action: drop
regex: ''
source_labels:
- __service__
- action: labelmap
regex: __meta_kubernetes_pod_label_(.+)
- action: replace
replacement: $1
separator: /
source_labels:
- __meta_kubernetes_namespace
- __service__
target_label: job
- action: replace
source_labels:
target_label: namespace
- action: replace
source_labels:
- __meta_kubernetes_pod_name
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
- job_name: kubernetes-pods-app
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
- action: drop
regex: .+
source_labels:
- source_labels:
- __meta_kubernetes_pod_label_app
- source_labels:
- action: drop
regex: ''
source_labels:
- __service__
- action: labelmap
- action: replace
replacement: $1
separator: /
source_labels:
- __service__
target_label: job
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
separator: /
source_labels:
- job_name: kubernetes-pods-direct-controllers
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
- action: drop
regex: .+
separator: ''
source_labels:
- action: drop
regex: '[0-9a-z-.]+-[0-9a-f]{8,10}'
source_labels:
- __meta_kubernetes_pod_controller_name
- source_labels:
- source_labels:
- action: drop
regex: ''
source_labels:
- __service__
- action: labelmap
- action: replace
replacement: $1
separator: /
source_labels:
- __service__
target_label: job
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
separator: /
source_labels:
- job_name: kubernetes-pods-indirect-controller
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
- action: drop
regex: .+
separator: ''
source_labels:
- action: keep
source_labels:
- action: replace
regex: '([0-9a-z-.]+)-[0-9a-f]{8,10}'
source_labels:
- source_labels:
- action: drop
regex: ''
source_labels:
- __service__
- action: labelmap
- action: replace
replacement: $1
separator: /
source_labels:
- __service__
target_label: job
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
separator: /
source_labels:
- job_name: kubernetes-pods-static
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
- action: drop
regex: ''
source_labels:
- __meta_kubernetes_pod_annotation_kubernetes_io_config_mirror
- action: replace
source_labels:
- __meta_kubernetes_pod_label_component
- source_labels:
- action: drop
regex: ''
source_labels:
- __service__
- action: labelmap
- action: replace
replacement: $1
separator: /
source_labels:
- __service__
target_label: job
- action: replace
source_labels:
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
separator: /
source_labels:
