Error: Data source connected, but no labels were received
Hi everyone!
Recently I installed Loki + Grafana Agent (flow mode) but when I added Loki as a data source I got the error: Data source connected, but no labels were received. Verify that Loki and Promtail are correctly configured.
Does anyone know how I can fix it?
Loki configuration:
loki:
  readinessProbe:
    httpGet:
      path: /ready
      port: http-metrics
    initialDelaySeconds: 30
    timeoutSeconds: 1
  auth_enabled: true
  storage:
    bucketNames:
      chunks: bucket-name
      ruler: bucket-name
      admin: bucket-name
    type: s3
    s3:
      region: us-east-2
      s3ForcePathStyle: false
      insecure: false
serviceAccount:
  create: true
  annotations:
    eks.amazonaws.com/role-arn: arn:aws:iam:::role/grafama-loki-role
test:
  enabled: false
monitoring:
  dashboards:
    enabled: false
  rules:
    enabled: false
  serviceMonitor:
    enabled: false
  selfMonitoring:
    enabled: false
  lokiCanary:
    enabled: true
write:
  replicas: 3
read:
  replicas: 4
backend:
  replicas: 3
gateway:
  enabled: true
  replicas: 1
  verboseLogging: true
  service:
    port: 80
    type: NodePort
    nodePort: 30001
  basicAuth:
    enabled: true
    username: test
    password: test
  readinessProbe:
    httpGet:
      path: /
      port: http
    initialDelaySeconds: 15
    timeoutSeconds: 1
Agent configuration:
agent:
  mode: 'flow'
  configMap:
    create: false
    key: config.river
  clustering:
    enabled: false
rbac:
  create: true
serviceAccount:
  create: true
  annotations: {}
configReloader:
  enabled: true
controller:
  type: 'daemonset'
service:
  enabled: true
  type: ClusterIP
  clusterIP: ''
  annotations: {}
ingress:
  enabled: false
config.river:
discovery.kubernetes "pods" {
  role = "pod"
loki.source.kubernetes "test" {
    targets    = discovery.kubernetes.pods.targets
    forward_to = [loki.write.loki.receiver]
loki.write "loki" {
  endpoint {
    url = env("LOKI_URL")
    basic_auth {
       username = env("LOKI_USERNAME")
       password = env("LOKI_PASSWORD")
Thanks in advance
I have similar situation
                role = "pod"
              loki.source.kubernetes "pods" {
                forward_to = [loki.write.multitenant.receiver]
              loki.relabel "app" {
                rule {
                  action        = "replace"
                  source_labels = ["__meta_kubernetes_pod_controller_name"]
                  regex         = "([0-9a-z-.]+?)(-[0-9a-f]{8,10})?"
                  target_label  = "__tmp_controller_name"
                rule {
                  action        = "replace"
                  source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_name","__meta_kubernetes_pod_label_app","__tmp_controller_name","__meta_kubernetes_pod_name"]
                  regex         = "^;*([^;]+)(;.*)?$"
                  target_label  = "app"
              loki.relabel "podName" {
                rule {
                  action        = "replace"
                  source_labels = ["__meta_kubernetes_pod_name"]
                  target_label  = "pod"
              loki.source.kubernetes_events "local" {
                job_name = "events"
              loki.write "multitenant" {
                endpoint {
                  url = "https://loki-multi.domain.com/loki/api/v1/push"
                  tenant_id = "{{metadata.labels.tier}}"
                external_labels = {
                  cluster = "{{name}}",
but have only this labels
job = loki.source.kubernetes.pods
instance="vault/vault-0:vault-init"
I encounter the same error trying to label the logs with the loki.relabel stage. I suggest you try with discovery.relabel for Kubernetes labels. The following configuration worked for me:
      role = "pod"
    discovery.relabel "logs" {
      rule {
        source_labels = [ "__meta_kubernetes_namespace" ]
        target_label  = "namespace"
      rule {
        source_labels = ["__meta_kubernetes_pod_label_app"]
      rule {
        source_labels = [ "__meta_kubernetes_pod_name" ]
      rule {
        source_labels = [ "__meta_kubernetes_pod_node_name" ]
        target_label  = "node"
      rule {
        source_labels = [ "__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name" ]
        target_label  = "__path__"
        separator     = "/"
        replacement   = "/var/log/pods/*$1/*.log"
    local.file_match "logs" {
      path_targets = discovery.relabel.logs.output
    loki.source.file "pods" {
      targets    = local.file_match.logs.targets
      forward_to = [ loki.process.logs.receiver ]
