Unable to fetch labels from Loki (Failed to call resource), please check the server logs for more details
    v9.3.6
    connect to loki data source from grafana
    installed components through helm chart
  • What happened?
    installed helm, grafana, promtail through helm charts and all are running successfully but I was unable to connect to loki data source from grafana
    get the logs in grafana dashboard
I checked all pods are up and running, loki is publishing metrics on
http://loki-backend:3100/metrics
but when I try to add the loki in grafana like this way http://loki-backend:3100 it is not connecting
here is my loki configmap value
auth_enabled: false
common:
  path_prefix: /var/loki
  replication_factor: 3
  storage:
    s3:
      access_key_id: enterprise-logs
      bucketnames: chunks
      endpoint: loki-minio.oal-loki-poc.svc:9000
      insecure: true
      s3forcepathstyle: true
      secret_access_key: supersecret
limits_config:
  enforce_metric_name: false
  max_cache_freshness_per_query: 10m
  reject_old_samples: true
  split_queries_by_interval: 15m
memberlist:
  join_members:
  - loki-memberlist
query_range:
  align_queries_with_step: true
ruler:
  storage:
    s3:
      bucketnames: ruler
    type: s3
runtime_config:
  file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
  configs:
    index:
      period: 24h
      prefix: loki_index_
    object_store: s3
    schema: v12
    store: boltdb-shipper
server:
  grpc_listen_port: 9095
  http_listen_port: 3100
storage_config:
  hedging:
    at: 250ms
    max_per_second: 20
    up_to: 3
table_manager:
  retention_deletes_enabled: false
  retention_period: 0
I intentionally removed “p” in http because site not allowing more than 2 links in a post
observation:
when I put the this in url (htt://loki-backend:3100 or htt://loki-gateway) I get message in log like this (error="404 page not found)
" logger=context userId=1 orgId=1 uname=admin t=2023-02-10T15:51:50.622326971Z level=error msg="Failed to call resource" error="404 page not found\n" traceID=
logger=context userId=1 orgId=1 uname=admin t=2023-02-10T15:51:50.622425027Z level=error msg="Request Completed" method=GET path=/api/datasources/3/resources/labels status=500 remote_addr=[::1] time_ms=6 duration=6.122883ms size=51 referer=htt://localhost:3001/datasources/edit/mYX3no0Vz handler=/api/datasources/:id/resources/"
when I put this in URL (htt://localhost:3100) I know the localhost is not right one in my case but for demo purpose I’m doing this (Get "htt://localhost:3100/loki/api/v1/labels?)
logger=context userId=1 orgId=1 uname=admin t=2023-02-10T15:53:20.514537443Z level=error msg="Failed to call resource" error="Get \"htt://localhost:3100/loki/api/v1/labels?start=1676043800268000000&end=1676044400268000000\": dial tcp [::1]:3100: connect: connection refused" traceID=
logger=context userId=1 orgId=1 uname=admin t=2023-02-10T15:53:20.514631089Z level=error msg="Request Completed" method=GET path=/api/datasources/3/resources/labels status=500 remote_addr=[::1] time_ms=3 duration=3.933432ms size=51 referer=htt://localhost:3001/datasources/edit/mYX3no0Vz handler=/api/datasources/:id/resources/
found the solution:
during the helm install it installed the chart with version 4.4.2 which installed lot of components and loki-backend but after removing 4.4.2 version and installed 2.16.0 chart version it only installed loki. This version worked fine and able to connect to loki data source from grafana
