enric
January 25, 2019, 7:41am
1
Hello, I tried to use the cloud demo instance with the demo Loki datasource, but I get the error:
Error connecting to datasource: Data source connected, but no labels received. Verify that Loki and Promtail is configured properly.
Any help would be appreciated.
Hi, I’m also receiving this error. I see the following in my k8s pod logs:
$ kubectl logs promtail-2cgpz -nmonitoring
level=error ts=2019-01-30T17:40:01.227043631Z caller=main.go:35 msg="error loading config" filename=/etc/promtail/promtail.yml err="yaml: line 33: mapping values are not allowed in this context"
i have deployed prometheus operator and loki charts 2 days before and work fine, I was updrade the grafana docker image and i have the error
I can retrieve logs from loki usin the api, i can understand that this part is working.
someone else?
Please try the latest master docker image. There was a bug causing this which should have been fixed.
Regarding cloud demo that should also been updated with bug fix so please try again.
Thanks @anon34853223 , much appreciated. I’m up and running now!
Hello.
The same error:
“Error connecting to datasource: Data source connected, but no labels received. Verify that Loki and Promtail is configured properly.”
Arises in 20-30 minutes if no new logs have been received. At the same time, the old ones also do not work
For containers I use these images:
grafana / grafana: 6.4.1
grafana / loki: master-52a9aa7
grafana / promtail: master-52a9aa7
c16a
January 3, 2020, 10:41am
7
I’m using Grafana v6.5.2 (commit: 742d165) and I’m still facing the issue.
My promtail config looks like this
server:
http_listen_port: 9099
positions:
filename: ./tmp/positions.yaml
clients:
- url: [LOKI_URL]
tenant_id: ec2
scrape_configs:
- job_name: log_scrape
pipeline_stages:
- json:
expressions:
level: level
- labels:
level:
static_configs:
- targets:
- localhost
labels:
job: omp_logs
host: localhost
__path__: /home/ec2-user/logs/*.log
Did I go wrong somewhere?
