I’m running kube-prometheus-stack, loki, and promtail and I’m having trouble connecting Loki as a Grafana datasource. I get the error message “Unable to connect with Loki. Please check the server logs for more details.”
I’ve shelled into the grafana pod and I can curl http://loki-gateway.monitoring.svc.cluster.local/ no problem. Funny thing is, I get 404s when I try to hit some endpoints like /ready, but others work totally fine like /loki/api/v1/status/buildinfo. This issue seems similar to Can't connect Loki to Grafana in k8s · Issue #13179 · grafana/loki · GitHub.
Any idea what could be going on? Have I misconfigured something? Any help you can provide is much appreciated.
I’m running the latest Loki chart (6.x), using the single binary deployment mode, and using the loki gateway. Here are my values.
deploymentMode: SingleBinary
loki:
commonConfig:
replication_factor: 1
storage:
type: "filesystem"
schemaConfig:
configs:
store: tsdb
index:
prefix: loki_index_
period: 24h
object_store: filesystem
schema: v13
singleBinary:
replicas: 1
read:
replicas: 0
backend:
replicas: 0
write:
replicas: 0
Here’s my Grafana datasource:
grafana:
additionalDataSources:
- name: Loki
access: proxy
isDefault: false
orgId: 1
type: loki
url: http://loki-gateway.monitoring.svc.cluster.local/
Looking through the Loki auth docs, I came across the requirement to pass the org ID in X-Scope-OrgID header, Multi-tenancy | Grafana Loki documentation. This is required if multi-tenancy is enabled, which it is by default in the helm chart. I wonder if this is causing the issue. I’ll give it a try.
Yep, the missing X-Scope-OrgID header was the issue. Here’s the fix. I added the header in jsonData and the value in secureJsonData.
grafana:
- name: Loki
access: proxy
isDefault: false
jsonData:
httpHeaderName1: X-Scope-OrgID
secureJsonData:
httpHeaderValue1: 1
orgId: 1
type: loki
You can also just disable multi-tenancy as well with auth_enabled: false.
loki:
auth_enabled: false
commonConfig:
storage:
type: "filesystem"
schemaConfig:
configs:
store: tsdb
index:
prefix: loki_index_
period: 24h
schema: v13
singleBinary:
replicas: 1
read:
replicas: 0
backend:
replicas: 0
write:
replicas: 0
I had faced the same issue.Previously loki deployed with simplescaling mode & even after putting auth disabled still asking for org id.Lastly I used below values.yaml & redeployed loki.After that grafana connected loki without org ID
auth_enabled: false
loki:
auth_enabled: false # Redundant, but ensures it’s explicitly set
commonConfig:
replication_factor: 1 # Important for SingleBinary mode
storage:
backend: filesystem # Changed from your previous s3. SingleBinary often uses filesystem for simplicity. If you need s3, we’ll adjust later.
schemaConfig:
configs:
store: tsdb
object_store: filesystem # Changed from your previous s3. SingleBinary often uses filesystem.
schema: v13
index:
prefix: loki_index_
period: 24h
ingester:
chunk_encoding: snappy
querier:
max_concurrent: 4
pattern_ingester:
enabled: true
limits_config:
allow_structured_metadata: true
volume_enabled: true
retention_config:
retention_period: 24h
singleBinary:
replicas: 1
read:
replicas: 0
backend:
replicas: 0
write:
replicas: 0
minio:
enabled: true
gateway:
service:
type: NodePort
