I everyone!
I’m trying to configure loki-stack in my HomeLab with kubernetes.
I can configure grafana/prometheus without problems, but I haven’t had any luck with Loki.
All resources are in the same namespace “Monitoring”
Is strange because when I do a curl since a grafana Pod
I get the response “ready”!
grafana-5f4d467645-68t25:/usr/share/grafana$ curl http://loki-stack:3100/ready
ready
But in the UI I get “Unable to connect with Loki. Please check the server logs for more details.”
In the Grafana logs I get the following error:
logger=context userId=1 orgId=1 uname=root t=2025-05-14T20:09:50.653762733-03:00 level=info msg="Request Completed" method=GET path=/api/datasources/uid/PFD47E6011A697DC0/health status=400 remote_addr=10.244.0.0 time_ms=213 duration=213.654982ms size=106 referer=https://grafana.homelab.com/connections/datasources/edit/PFD47E6011A697DC0 handler=/api/datasources/uid/:uid/health status_source=server
Has anyone had a similar situation?
I’d really appreciate it if you could help me.
Best regards!
